POV-Ray : Newsgroups : povray.advanced-users : dot-notation not allowed in functions? : Re: dot-notation not allowed in functions? Server Time
13 Aug 2026 17:36:03 EDT (-0400)
Date: 31 Jul 2018 15:36:14
Message: <5b60ba2e$1@news.povray.org>
Am 31.07.2018 um 20:31 schrieb Thorsten Froehlich:
>> That said, "as designed and documented" doesn't necessarily mean that
>> it's free from issues that might warrant fixing. It might just be that
>> there's a problem with the design.
>> And I for one would argue that that's indeed the case (presuming dot
>> notation has been excluded from functions by design rather than by
>> oversight). Because - evidently - this behaviour goes against user
>> expectations.
> It is logically correct in a properly (given you worked on the tokenizer you
> know what I mean) designed parser: Functions cannot access declared values
> because functions persist after parsing. This would require substituting the
> preprocessor-level declared variable with the value of the variable. This value
> would be a vector, which isn't supported.
I don't see an issue there.
It would be a valid point if the dot operator were to be implemented as
an operation in the function VM.
However, since we are talking about `SDL_VARIABLE.x` (and siblings)
here, and not `FUNCTION_PARAMETER.x`, I see no sound reason why the
function parser couldn't resolve the operation at parse-time.
The rule would be pretty simple:
If the token is an SDL variable holding a vector or colour, take a peek
at the next token. If that token is a dot, expect a component name, and
inject the respective value into function. If the token is not a dot (or
the component name is invalid), raise an error.
