HI there, i have look around the forums and find an interesting glowing
effekt.
I tried to copy it from the glow_spehre i found but in wont work with text.
Maybe this possible? I made the text object holow but nothing will work.
Tabea
prog so i
i tried some out for deciding
Was it a material with interior and media emitting color?
Had this media a density pattern?
I yes, try to delete this density.
Marc
web.3e940928b1c891b2b26ab750@news.povray.org...
> HI there, i have look around the forums and find an interesting glowing> effekt.> I tried to copy it from the glow_spehre i found but in wont work with
text.
> Maybe this possible? I made the text object holow but nothing will work.>> Tabea>> prog so i> i tried some out for deciding>
Thanks Mark,
the failure was the density. I removed it and it works. But i dont
understand how to use density and when not. And is there a possibility that
the text object will be seen sharp (as no glow) an there will be glowing
around and not coming form inside??
Tabea
Marc Jacquier wrote:
>Hi,>Was it a material with interior and media emitting color?>Had this media a density pattern?>I yes, try to delete this density.>Marc>
