Help!!
Once more, Moray crashed and I am unable to retart it!
I had it linked to POV-Ray 3.5 (with some problems related to script
mentions of other versions in additional inc files). Finally it worked
(yesterday), but today Moray started to crash wether called directly or
through POV-Ray.
I re-installed the program, but to no avail. It loads the plugin, then stops
when opening the program.
I know that Lutz some time ago told here what to do in such a case, but I
cannot find that particular message, so (sorry Lutz!) could you tell me/us
again? Something to do with the registry, isn't it?
Hi Thomas de Groot, you recently wrote in moray.win:
Hmmm, I really would like to know what it's doing. Does it display a
message?
Can you please do this:
Open RegEdit (Start|Run|RegEdit). Navigate to
HKEY_CURRENT_USER\Software\SoftTronics, right-click on that key (on
the left pane) and select Export. Choose any name you like and then
send me that file per email (lut### [at] stmuccom). Thanks.
To alleviate the problem it might help to simply delete that same key.
In other words, right-click on the same item
(HKEY_CURRENT_USER\Software\SoftTronics) and select Delete. MAKE SURE
YOU DON'T SELECT ANOTHER KEY!
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Thomas,
Was this error caused when you used the link plugin?
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:3d43efa8@news.povray.org...
> Help!!
> through POV-Ray.
stops
> Thomas
No, this particular plugin was not in use in the current startup scene. Nor
any other by the way. Nor did Moray give any error message.
I sent the registry to Lutz and deleted the mentioned register key, and all
functions again. But it remains a mistery to me...
"Tony Vigil" <tjv### [at] hotmailcom> schreef in bericht
news:3d45b0c0$1@news.povray.org...
> Thomas,
> > Help!!
> > through POV-Ray.
> stops
I
me/us
> > Thomas
