Is there a way to manipulate a image map on a height field, e.g. if I use a
material that contains an image map how do I translate and scale the
material map so it does not tile on the height field.
thanks
Mitch Waite
former publisher of Ray Tracing Creations, Image Lab and Fractal Creations
Hi Mitch,
you know, I was wondering whether it was you, I was just too shy to
ask :-). Wonderful to hear from you!
> Is there a way to manipulate a image map on a height field, ...
Sure. Once the image map material has been assigned to the
heightfield, it will be displayed as a green scquare. You can select
this square (either with Alt-T or graphically with the mouse) and then
scale and translate it into position, in this case preferably in the
TOP view.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Subject: Re: Manipulating a image map in Moray
Date: 31 Dec 2001 14:04:49
Message: <3c30b6d1@news.povray.org>
Excellent, thank you thank you, that was just what I needed.
I'm having fun with the new Moray, its an amazing improvment. I tried
fighting with Bryce on the Mac and got really frustrated with its interface,
then switched to Moray and it was like taking candy from a baby, soooo EZ.
(course I would never take candy from any baby :)
Mitch
PS I see how Alt T selects the material, but did not see it listed in the
Select tab so I could select it with the mouse like I select other objects.
Is there a way to make it show up in that list?
"Lutz Kretzschmar" <lut### [at] stmuccom> wrote in message
news:22a03uo4nmeq1jduig1ae8uec9b0q4nqu8@4ax.com...
> Hi Mitch,
> TOP view.
> Regards,
> - Lutz
Hi Mitchell Waite, you recently wrote in moray.win:
No, it's not listed there. You can select it with the mouse in the
views just like you select objects (Shift-Drag).
- Lutz
