POV-Ray : Newsgroups : moray.win : Textobject problem Server Time
27 Sep 2024 11:27:46 EDT (-0400)
  Textobject problem (Message 1 to 10 of 16)
Subject: Textobject problem
Date: 27 Apr 2001 12:21:37
Message: <3ae99c91@news.povray.org>
Hi @ all,
I use moray 3..3 to get some nice logos for my coverart.
i tried to use a special font (frozen dog treats) and moray
showed it as
exspected, but as i rendered the whole thing some of the
they were replaced by other characters, that not present in
this special font.
what did i wrong ?
does this appear to someone else ?
is this a moray or povray problem ?
or even a windows problem ?
thanks
hkn
Subject: Re: Textobject problem
Date: 27 Apr 2001 14:36:25
Message: <3AE9BC28.55580959@ucdavis.edu>
which version of povray are you using?  IIRC, pov 3.1 doesn't handle
fonts as well as megapov does.  i could be wrong though.  you can render
to megapov by putting the megapov exe in the same place as the pov exe,
changing the name of the pov exe to something else, and the name of
megapov to pov's original name.  that way all programs that call pov can
find it easily.
Hakan Kocaman wrote:
> Hi @ all,
> showed it as
> this special font.
> what did i wrong ?
> thanks
> hkn
Date: 27 Apr 2001 15:40:47
Message: <MPG.1553d46c239c2d4e9898ee@news.povray.org>
On Fri, 27 Apr 2001 11:36:24 -0700, Ryan Constantine wrote...
> find it easily.
Or you can use MegaPOV far more easily by pressing alt-F9, and changing
the POV-ray executable to the megapov executabe of your choice without
having to go through all the hassle of copying and renaming files...
Bye for now,
     Jamie.
Date: 27 Apr 2001 17:29:38
Message: <3ae9e4c2@news.povray.org>
"Jamie Davison" <jam### [at] ntlworldcom> schrieb im
Newsbeitrag
news:MPG.1553d46c239c2d4e9898ee@news.povray.org...
wrote...
doesn't handle
you can render
as the pov exe,
the name of
that call pov can
> > find it easily.
and changing
choice without
renaming files...
> Bye for now,
>      Jamie.
Thanks to you two.
bye
hkn
Date: 28 Apr 2001 06:09:12
Message: <vh5letspu0pjenfugrlkqbpaf0hfjtqdmh@4ax.com>
Hi Hakan Kocaman, you recently wrote in moray.win:
> showed it as > exspected, but as i rendered the whole thing some of the
POV-Ray may have trouble with the font, especially if the characters
you are using are above 128 ASCII. If you like, you can send me the
font file and the MDL file and I can take a look.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 28 Apr 2001 15:39:52
Message: <3AEB1D60.79634B04@yahoo.com>
the reason i prefer renaming is because other programs that use pov
don't have the dialog like moray does.  for example, texture view looks
only for pvengine.exe.  so if you were to try to render a megapov
texture it wouldn't work.  so to be safe, i do the renaming game. :)
> > find it easily.
> Bye for now,
>      Jamie.
Date: 28 Apr 2001 18:47:26
Message: <MPG.155558dfe5cf4e079898f3@news.povray.org>
On Sat, 28 Apr 2001 12:43:28 -0700, Ryan Constantine wrote...
Whatever works for you, but the only real POV application I use is Moray,
so I find the alt-F9 trick works well for me.
(or, what I really think)
Masochist...
<grin>
Bye for now,
     Jamie.
Date: 29 Apr 2001 16:30:50
Message: <3aec79fa@news.povray.org>
Newsbeitrag
news:MPG.155558dfe5cf4e079898f3@news.povray.org...
wrote...
that use pov
texture view looks
a megapov
renaming game. :)
I use is Moray,
Thanks for your help :)
I tried the "renaiming"-method and it worked fine,
is this also an easy way to upgrade to other enginges ? nice
by the font
are their maybe special 3d-fonts to use with moray, i
searched at povray, but found nothing.
maybe i try another way
by hkn
> Masochist...
> <grin>
> Bye for now,
>      Jamie.
Date: 29 Apr 2001 16:39:57
Message: <3aec7c1d@news.povray.org>
"Lutz Kretzschmar" <lut### [at] stmuccom> schrieb im Newsbeitrag
news:vh5letspu0pjenfugrlkqbpaf0hfjtqdmh@4ax.com...
moray
thing some of the
characters
send me the
Thanks,
window-integrated.
is art really fun :~)
bye
HKN
Date: 29 Apr 2001 16:41:58
Message: <MPG.15568d06516261179898f8@news.povray.org>
It's a way to use other, patched and third party compiled versions of
POV, but it wouldn't allow you to use another renderer which isn't 100%
POV code compliant.
> by the font
> by hkn
If you want to post the .mdl files and the offending font fil in
moray.binaries, I'll have a look at it and see if I can spot anything
obviously wrong with it.
Bye for now,
     Jamie.
