POV-Ray : Newsgroups : moray.win : Hamapatch and Moray Server Time
27 Sep 2024 13:23:05 EDT (-0400)
  Hamapatch and Moray (Message 1 to 7 of 7)
Subject: Hamapatch and Moray
Date: 24 Mar 2001 13:28:45
Message: <3abce75d@news.povray.org>
Hi!
This is a little something I've been thinking 'bout:
For modelling organic objects, I've been using sPatch 'till I founded
Hamapatch that still is in developing process (not stopped an lost as
sPatch).
My problem is that when I've done all the work in Hamapatch, I have to
export it to sPatch, and then, from sPatch, export it to Moray.
What about a plugin to export directly from hamapatch to Moray, or a plugin
to import hamapatch files into Moray?. There would be no limitations on
layers (sPatch only allow 8), and sPatch will not be needed anymore as a
middle step to export to Moray files created with Hamapatch.
It's just a wish, I don't know if it's possible or not.
Comments?
Txemi Jendrix
tji### [at] euskalnetnet
http://home.dencity.com/tji
Subject: Re: Hamapatch and Moray
Date: 26 Mar 2001 02:10:27
Message: <afutbtc9bg0jgsr8cn9onk4mnt2nult410@4ax.com>
Hi Txemi Jendrix, you recently wrote in moray.win:
Does Hamapatch have export filters? Or is the file format
well-defined? I guess it probably wouldn't be all that difficult if
the files were easy to read....
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 26 Mar 2001 16:22:22
Message: <3abfb30e@news.povray.org>
As far as I have seen in the folder where it's the program there's one file
called hamapatch.exe (1.08 Mb) and these other ones:
hama.ini (1,360 bytes)
hama_resource_type.ini (7 bytes)
hama_shorcut.ini (696 bytes)
hama_wnd.ini (82 bytes)
There are no external plugins files.
I have no idea if the file format is well-defined (I am no programmer at
all).
I'll send an e-mail to its author to ask about the possibility to implemet a
way to export to Moray, and I'll tell you the answer (if I get one).
Thanks anyway Lutz
Txemi Jendrix
news:afutbtc9bg0jgsr8cn9onk4mnt2nult410@4ax.com...
> - Lutz
Date: 28 Mar 2001 17:45:59
Message: <3AC269B0.2D285873@mninter.net>
No, I wouldn't say that its particularly easy to read- here is a tube:
light_info
material_info    wnd_info       A                   B
A                       B       background_info       include_file
No idea how one sorts out all this gibberish.
OTOH, it does export to sPatch files, so perhaps a Moray plugin to import sPatch
files would be in order(and I'm pretty sure that those are easily readable),
rather than just the sPatch plugin. Or, one could just export to sPatch files,
load it in sPatch, then export it to Moray. A little roundabout, but easier than
writing a plugin.
> - Lutz
 "Art thou less a slave by being favoured by thy master?"
Pascal, Pensees, 1670
Date: 29 Mar 2001 01:51:42
Message: <0rm5ctkcvcmtvl59fapgibs58pp8mkpscn@4ax.com>
Hi Alex Magidow, you recently wrote in moray.win:
It's a binary format, so it's probably hard to parse if you don't have
the specs.
- Lutz
Date: 29 Mar 2001 06:44:10
Message: <3ac3200a@news.povray.org>
> the specs.
a bit like somebody else's file format then, eh Lutz <g>
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 31 Mar 2001 04:53:14
Message: <c6abctki9250hrsvb76i0d5a6doaheq9s3@4ax.com>
Hi Rick [Kitty5], you recently wrote in moray.win:
Now who might you be talking about? :-)  Touche...
But that is why Moray has a plugin interface to get at all the stuff.
- Lutz
