POV-Ray : Newsgroups : moray.win : Bump map Server Time
27 Sep 2024 15:20:41 EDT (-0400)
  Bump map (Message 1 to 7 of 7)
Subject: Bump map
Date: 16 Nov 2000 17:07:06
Message: <3a145a8a@news.povray.org>
can someone explain how to make a material with a bump map as usual in other
renderers?
I want to make a wallpaper with a structure.
Thanks,
-C-H-A-R-L-E-S-
Subject: Re: Bump map
Date: 17 Nov 2000 15:17:01
Message: <MPG.147f99dc6f659ce698984b@news.povray.org>
On Thu, 16 Nov 2000 23:11:17 +0100, Charles wrote...
> Hi,
> renderers?
Possibly the easiest, and in my opinion, preferable, method to use to get
structure in your wallpaper is straightforward normals.
However, If you want more control over the surface, then you can specify
a bump map quite easily.
Start Moray (obviously)
Press F8 to bring up the texture editor.
Create a new texture, giving it whatever pigment you want.
Create a normal, and from the context menu, select bump map.
From then on, you're into the realms of tweaking parameters to fit the
file you use for your bump map.
Have fun.
Bye for now,
     Jamie.
Date: 18 Nov 2000 17:57:20
Message: <3a170950@news.povray.org>
"Jamie Davison" <jam### [at] dh70qdu-netcom> wrote in message
news:MPG.147f99dc6f659ce698984b@news.povray.org...
> > renderers?
Butting in here, perhaps the idea needs a height_field.  Surface relief.  I'm sure
Moray must have that feature
available in some way.
Date: 19 Nov 2000 04:43:18
Message: <MPG.14811f1e373f936e98984f@news.povray.org>
On Sat, 18 Nov 2000 16:57:02 -0600, Bob H. wrote...
> > > renderers?
By all means, butt in.
Yep, you can create HF's in Moray.  It'll even give you a representation
of the HF so you can make sure you've gotten them the right way round.
The main problem I have with HF's is the sheer size of the image files
you need to get a decent result with more complex designs, and the memory
consumption you run into when you use several HF's referencing different
source images.
In the Create Tab, click Heightfield, which should be in the fifth row of
buttons down.
Excuse me if this reads as a little confused, but I just finished playing
Escape From Monkey Island... (Chapter 1 completed so far)
Bye for now,
     Jamie.
Date: 19 Nov 2000 07:20:48
Message: <3a17c5a0@news.povray.org>
"Jamie Davison" <jam### [at] dh70qdu-netcom> schrieb im Newsbeitrag
Hi Jamie,
thanks for the tip.
Curious, not to find in the POV documentation, where I looked first. No word
about bump_map.
And there is a little prob, see moray.beta.
-C-H-A-R-L-E-S-
Date: 19 Nov 2000 10:32:22
Message: <3A17F30B.F23FD5E4@pacbell.net>
> about bump_map.
Bump mapping is part of the normal feature and is well documented.
Bump Maps
When all else fails and none of the above normal pattern types meets your
needs you can use a bump_map to wrap a 2-D bit-mapped bump pattern around
your 3-D objects.
Instead of placing the color of the image on the shape like an image_map
a bump_map perturbs the surface normal based on the color of the image at
that point. The result looks like the image has been embossed into the
surface. By default, a bump map uses the brightness of the actual color
of the pixel. Colors are converted to gray scale internally before
calculating height. Black is a low spot, white is a high spot. The image's
index values may be used instead (see section "Use_Index and Use_Color"
below).
Specifying a Bump Map
The syntax for an bump_map is:
BUMP_MAP:
normal{
bump_map{ BITMAP_TYPE "bitmap.ext" [BUMP_MAP_MODS...] }
[NORMAL_MODFIERS...]
BITMAP_TYPE:
gif | tga | iff | ppm | pgm | png | sys
BUMP_MAP_MOD:
map_type Type | once | interpolate Type |
use_color | use_colour | bump_size Value
After the required BITMAP_TYPE keyword is a string expression containing
the name of a bitmapped bump file of the specified type. Several optional
modifiers may follow the file specification. The modifiers are described
below. Note that earlier versions of POV-Ray allowed some modifiers before
the BITMAP_TYPE but that syntax is being phased out in favor of the syntax
described here. Note sys format is a system-specific format such as BMP for
Windows or Pict for Macintosh.
Filenames specified in the bump_map statements will be searched for in the
home (current) directory first and, if not found, will then be searched for
in directories specified by any +L or Library_Path options active. This
would facilitate keeping all your bump maps files in a separate subdirectory
and giving a Library_Path option to specify where your library of bump maps
are. See "Library Paths" for details.
By default, the bump pattern is mapped onto the x-y-plane. The bump pattern
is projected onto the object as though there were a slide projector somewhere
in the -z-direction. The pattern exactly fills the square area from (x,y)
coordinates (0,0) to (1,1) regardless of the pattern's original size in
pixels. If you would like to change this default you may translate, rotate
or scale the pigment or texture to map it onto the object's surface as
desired. If you would like to change this default orientation you may
translate, rotate or scale the pigment or texture to map it onto the object's
surface as desired.
The file name is optionally followed by one or more BITMAP_MODIFIERS. The
bump_size, use_color and use_index modifiers are specific to bump maps and
are discussed in the following sections. See section "Bitmap Modifiers" for
the generic bitmap modifiers map_type, once and interpolate described in
"Bitmap Modifiers"
Bump_Size
The relative bump size can be scaled using the bump_size modifier. The bump
size number can be any number other than 0 but typical values are from about
0.1 to as high as 4.0 or 5.0.
  normal {
    bump_map {
      gif "stuff.gif"
      bump_size 5.0
Originally bump_size could only be used inside a bump map but it can now be
used with any normal. Typically it is used to override a previously defined
size. For example:
  normal {
    My_Normal   //this is a previously defined normal identifier
    bump_size 2.0
Usually the bump map converts the color of the pixel in the map to a gray
scale intensity value in the range 0.0 to 1.0 and calculates the bumps based
on that value. If you specify use_index, the bump map uses the color's palette
number to compute as the height of the bump at that point. So, color number 0
would be low and color number 255 would be high (if the image has 256 palette
entries). The actual color of the pixels doesn't matter when using the index.
This option is only available on palette based formats. The use_color keyword
may be specified to explicitly note that the color methods should be used
instead. The alternate spelling use_colour is also valid. These modifiers
may only be used inside the bump_map statement.
Ken Tyler
Date: 19 Nov 2000 12:48:26
Message: <3a18126a@news.povray.org>
"Ken" <tyl### [at] pacbellnet> schrieb im Newsbeitrag
news:3A17F30B.F23FD5E4@pacbell.net...
word
> > about bump_map.
I thought so too and was astonished not to find it. My mistake was to use
search and index, there you will find no results.
Thank you very much, I've got it now.
-C-H-A-R-L-E-S-
