FYI, the animation plugin (beta 19) doesn't work with POV 3.5...
it only renders the first frame.
And why do I have beta 19, while the version on Xander's site
is beta 18?
Tim Cook
Version: 3.12
Subject: Re: Animation Plugin
Date: 2 Dec 2001 14:42:40
Message: <3C0A85E7.A52F1F30@gmx.de>
Timothy R. Cook wrote:
> FYI, the animation plugin (beta 19) doesn't work with POV 3.5...> it only renders the first frame.>> And why do I have beta 19, while the version on Xander's site> is beta 18?>
Hi Tim!Maybe you forgot to install the GUI-Extension in povray?
alex
Date: 3 Dec 2001 20:10:01
Message: <3c0c2269@news.povray.org>
> > Hi Tim!Maybe you forgot to install the GUI-Extension in povray?>> Nope, I've got the GUI-extension turned on...still doesn't work.> Should I try re-installing stuff?
I have the same problem - reinstalling did nothing for me.
PGP Public Key
Look in the file PVENGINE.INI in your povary /ini directory. Under the
[GUIExtentions] section, add the line 'ExtDll29=C:\Program Files\Moray For
Windows\Plugins\AnimGuiExt.dll' (without quotes). Replace the path with your
path to the AnimGuiExt.dll file. Also look over the animplugin.doc in the
moray plugin directory.
JohnN wrote:
> Look in the file PVENGINE.INI in your povary /ini directory.> Under the [GUIExtentions] section, add the line 'ExtDll29=C:\> Program Files\Moray For Windows\Plugins\AnimGuiExt.dll' (without> quotes). Replace the path with your path to the AnimGuiExt.dll> file. Also look over the animplugin.doc in the moray plugin> directory.
Sweet! That fixed it! Thanx!
Tim Cook
Version: 3.12
