POV-Ray : Newsgroups : moray.win : animation plugin Server Time
27 Sep 2024 17:24:19 EDT (-0400)
  animation plugin (Message 1 to 10 of 12)
Subject: animation plugin
Date: 2 Jul 2000 18:04:27
Message: <395fbc6b@news.povray.org>
is there a way to change the type of movement (ie step, linear, cubic)
between frames (ie step from 0:0 to 0:1, linear from 0:1 to 0:2 etc,)  or to
change the type of movement for different objects?
  also, not to pester or anything, but the features mentioned in the docs
that aren't implemented yet; are they being worked on ? or has the plugin
been put on the back burner?  also, is there a way to define an animation
for an object and save just that part?  the idea is this: i have a
spaceship.  it has landing gear which can be animated.  it has other parts
that can be animated as well.  i don't need them to animate in every scene i
plan on doing.  however, it would be nice to not have to reanimate them
(along with other things in the scene) just to do another scene.  the ideal
thing would be to import just that animation information (or parts of it)
and merge it with the scene and simply specify the time interval it should
take place.  also, i noticed that the plugin doesn't make use of the clock
variable.  actually, moray doesn't really allow the implementation of any of
the programming aspects of povray, which is too bad.  it would be nice if
there were some editor window or something in moray that would let you add
pov script.  this would be especially valuable for arrays, loops, functions,
and for manually adding the 'latest' megapov improvements, without having to
support them natively.  moray could simply implement a 'script' member
variable to the appropriate object or scene class...
Subject: Re: animation plugin
Date: 2 Jul 2000 18:09:44
Message: <395fbda8@news.povray.org>
by the way, this is ryan constantine over at my mom's for sunday dinner.  so
if you'd rather email me, the address is rco### [at] yahoocom and not the
one below (my mom's).  thank you.
April <aco### [at] prodigynet> wrote in message
news:395fbc6b@news.povray.org...
to
i
ideal
of
functions,
to
Date: 2 Jul 2000 18:14:58
Message: <395fbee2@news.povray.org>
sorry, one more question:  i couldn't get the wireframe render to work.  am
i missing something? it just crashed the program.  thanks...again.
ryan
to
i
ideal
of
functions,
to
Date: 2 Jul 2000 18:23:33
Message: <395fc0e5@news.povray.org>
yet another question (sorry i didn't think of them all at once):  is there a
way to animate something along a bezier spline as a path where you would
specify the spline, then specify the start and end points that you want your
model to go between?  this would allow an object to travel in a general
direction less robotically.  i'm thinking that the planned features for the
plugin would take care of this problem (being able to manipulate curves on
the timeline).
ryan
to
i
ideal
of
functions,
to
Date: 2 Jul 2000 23:29:03
Message: <pu10ms422aj9ci1tqafeo9535cfj88mbp0@4ax.com>
On Sun, 2 Jul 2000 15:25:22 -0700 "April" <aco### [at] prodigynet>
<snip..>
>news:395fbc6b@news.povray.org ...
<snip..>
  Not a problem, Ryan. Also, you needn't quote your original post
*three* times :)
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 3 Jul 2000 17:02:12
Message: <3960FF8B.E3B691C7@istar.ca>
Hi Ryan's Mom!
*waves*
Simon
Date: 4 Jul 2000 05:08:18
Message: <39619EF8.23CD7417@yahoo.com>
i guess this means nobody has answers for me?
> Hi Ryan's Mom!
> *waves*
> Simon
Date: 4 Jul 2000 09:32:36
Message: <3961E65F.E0F2807@pacbell.net>
...or it means those people that have the answers have not read
your messages yet.
Date: 5 Jul 2000 09:47:16
Message: <39633E51.729641E2@mitre.org>
Perhaps we are all at the beach (very nice holiday weather in New
England right now).  Saw quite a few whales about 16 miles off Cape Cod
on Monday.
Xander
> > Hi Ryan's Mom!
> > *waves*
> > Simon
Date: 5 Jul 2000 10:48:17
Message: <39634C9E.8A2A6E95@mitre.org>
Currently, the spline type is the same over the entire animation.
Individual pieces of an object (in group or CSG) can use different types
of splines (step, linear, cubic).  Separate objects can also use
different types of splines.
If you want the type of motion to be different, you can always break up
your animation into separate scenes.  This isn't all that different from
typical production - you rarely have more than a second or two of an
animation in one scene.  Of course, I need to beef up the
cut/paste/merge capabilities to make life easier when you do that.
There is currently a problem I'm working on with Lutz to address merging
of objects/scenes.  Until that is fixed, you are stuck.  It requires
changes to both Moray and the animation plugin.
The animation plugin gets attention when real life isn't interfering.  I
am continuing development, but at the moment there are a few structural
changes that have to be made.  Beefing up the timeline editor is one of
the highest priorities.
  the ideal
> take place.
Half of what you want is there.  You can rescale time for an individual
object.  So if you define the animation sequence over a certain time
period, you can always stretch/shrink it to fit the time period you
really wanted.
> ...  also, i noticed that the plugin doesn't make use of the clock
> variable.
Nope.  I suppose I could set appropriate values at the point in time the
.ini file is built by Moray.  I would continue to render a single frame
at a time though.  I'll add that to the to-do list.
> ...  actually, moray doesn't really allow the implementation of any of
> pov script.
Do you have some sort of aversion to using the "includes" tab in the
scene settings dialog?  That plus notepad gives you the ability to add
anything you want to a Moray scene.
Xander
