POV-Ray : Newsgroups : moray.win : Question about galaxy plugin Server Time
27 Sep 2024 19:29:21 EDT (-0400)
  Question about galaxy plugin (Message 1 to 4 of 4)
Subject: Question about galaxy plugin
Date: 12 May 2000 04:19:13
Message: <391bbe81@news.povray.org>
I couldn't get it to work. It always renders a black image.
  Every value is 0 by default, but altough I put the correct default values
for every parameter, it still rendered a black image. Am I doing something
wrong? (There's nothing else in the image, only the galaxy "object")
  Btw: I think that it would be a good idea to put the default values to
those that the galaxy include itself uses, instead of all 0. This way you
get the default galaxy and you can start modifying from there.
Subject: Re: Question about galaxy plugin
Date: 12 May 2000 07:52:10
Message: <391BF05F.8A69579A@umh.ac.be>
I remember that I had some problem with this, but I am just trying
with default settings (which are not equal to 0) and I got a good
picture (check your e-mail). I use moray 3.2 with the latest
plugin and you? (I also done the test on NT, I need to test at home
on 98).
Fabian.
Date: 13 May 2000 08:42:10
Message: <391D4E2C.B94BF783@totalise.co.uk>
Hi Warp,
The usual reason for a black image is that the include
files are not being found, this is usually caused by
placing them in the povscn dir and then overwriting them
with the scene file e.g. if you create an mdl called
galaxy.mdl and export it to Pov, Moray creates galaxy.inc
and galaxy.pov therefore if you have the galaxy.inc files
in povscn they will be overwritten. However it looks like
you have a different problem, have you got the latest
version of the galaxy plugin? for the correct version of
Moray?
Best Regards,
Keith
Date: 14 May 2000 15:06:56
Message: <391EF9A9.7F575BFA@t-online.de>
Hi Warp,
I had the problem that no nebulae or star objects showed up. There were
just some small stars on a black background. I fixed it by moving the
camera in the way that it looks directly on the x-y plane (or was it the
x-z plane?). Maybe that helps...
Karl
