POV-Ray : Newsgroups : moray.win : inverse kinematics Server Time
27 Sep 2024 19:30:05 EDT (-0400)
  inverse kinematics (Message 1 to 9 of 9)
Subject: inverse kinematics
Date: 22 Apr 2000 01:50:10
Message: <39013E24.8B08E111@yahoo.com>
question:  given two telescoping arms and a pivot between them, is there
a way to fix the ends of the arms and only move the pivot?
[]-------0----[]
[]----0-------[]
  0-
      -0
etc.
where [] are fixed and 0 is the pivot and - or \ is a telescoping arm
also is there a way to make circular IK relationships (ie a triangle or
a square with one fixed point; or a triangle where one arm is longer
than the triangle?)
Subject: Re: inverse kinematics
Date: 24 Apr 2000 06:44:46
Message: <3198gssq1q3cube84jna6iaiqm9ilk9l8l@4ax.com>
Hi ryan constantine, you recently wrote in moray.win:
Nope, sorry. IK is purely hierarchical (at least in Moray's
implementation.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 24 Apr 2000 06:49:24
Message: <390426b4$1@news.povray.org>
workaround idea: duplicate the end-object (the "0" in your "image") and
create two telescopic arms (one from the left, one from the right) that
each "end" in one of those "0"s. Then just translate both "0"s to the
same position, and mark only one of them for export.
Johannes.
"ryan constantine" <rco### [at] yahoocom> wrote in message
news:39013E24.8B08E111@yahoo.com...
there
> []-------0----[]
> []----0-------[]
>   0-
>       -0
> etc.
or
> than the triangle?)
Subject: OT: Tree Designer [Was:Re: inverse kinematics]
Date: 24 Apr 2000 08:06:33
Message: <390439A3.180ED36B@mninter.net>
Hey, Johannes- what ever happened with Tree Designer? Are any new versions
slated for release, or is it to stay in the somewhat perpetual, sPatch like
stasis that it has been in ever since release 1?Is there not enough
consumer demand? If so, would you ponder releasing it as freeware(maybe
even open source?)?
TIA,
Alex Magidow
> Johannes.
> there
> > []-------0----[]
> > []----0-------[]
> >   0-
> >       -0
> > etc.
> or
> > than the triangle?)
You Know You've Been Raytracing Too Long When:
 You purchase Toy Story for inspiration- Then do a better version for fun.
Produced by Alex Magidow's Sig File Randomizer(YKYBRTTL jokes courtesy of
c.g.r.raytracing)
Subject: Re: Tree Designer [Was:Re: inverse kinematics]
Date: 25 Apr 2000 07:37:25
Message: <39058375@news.povray.org>
"Alex Magidow" <axi### [at] mninternet> wrote in message
news:390439A3.180ED36B@mninter.net...
versions
like
Well yes, unfortunately this has been so since v. 1 and will likely
continue like that, probably out of the same reasons sPatch is in
statis: Real life interference...
> Is there not enough consumer demand?
> even open source?)?
I am pondering... :)
Johannes
Date: 25 Apr 2000 08:02:23
Message: <39058A28.DD7D76CE@mninter.net>
> versions
> like
> > even open source?)?
If you do ponder it into freeware, then disappear into the abyss, could you
release the source code first so that it doesn't stay at a constant level of
development like sPatch, or at least whip up a plugin system of some sort?
sPatch has stayed maddeningly the same since...1/19/98 according to the
website...and its darn difficult to get ahold of Mike Clifton...so please
don't disappear into the abyss...and if you do, please leave something
behind...
> Johannes
c.g.r.raytracing)
Date: 25 Apr 2000 18:38:38
Message: <39061E6E.70BF6DF5@videotron.ca>
In what was sPatch written?
Anyway, Clifton might just be reading this ng 8)
> behind...
AKA paul_virak_khuong at yahoo.com, pkhuong at deja.com, pkhuong at
crosswinds.net and pkhuong at technologist.com(list not complete)...
Date: 25 Apr 2000 21:23:55
Message: <39064606.2D8D862E@mninter.net>
Actually, to be perfectly accurate, he's not allowed to release the source code,
whatever teh program is written in...thats why I suggested a plugin api as an
alternative to free source.
> > behind...
c.g.r.raytracing)
Date: 3 May 2000 05:27:12
Message: <35svgs4pp8gsp74dabribmte263j8bmqn3@4ax.com>
Hi Johannes Hubert, you recently wrote in moray.win:
Yes, this is a good idea. I also thought about letting Moray do this
by making the second copy a reference. So when you move the original,
the reference moves with it anyway, but at the moment it doesn't
realize it is at the end of an IK chain. Maybe next version will
support this....
- Lutz
