POV-Ray : Newsgroups : moray.win : geometry Server Time
27 Sep 2024 15:25:03 EDT (-0400)
  geometry (Message 1 to 4 of 4)
Subject: geometry
Date: 20 Oct 2000 13:20:35
Message: <34v0vso0datjndkldt3jre8bii1dire9b7@4ax.com>
I am having a problem with orienting objects in CSG's. Due to my poor
math skills I can't seem to figure it out.
I want to use one cube to cut another cube using a difference CSG.
Sort of like making a pyramid by cutting a cube. However, unlike a
pyramid the cutting cube I want to use is not square to any axis.
Since I am trying to model something specific using the CSG I would
like to position the cutting cube precisely.
I know the coordinates of three points on the cube to be cut which I
want to hit with the cutting cube. Does anyone know a procedure to
determine from these points the rotation angles (x,y,z) I need to
place the cutting object where I want it?
Right now I have to use trial and error and lots of renderings to get
the results I want by making slight tweaks to the rotations. Perhaps
there is a better way?
Thanks for any help,
Stefan
Subject: Re: geometry
Date: 20 Oct 2000 13:36:41
Message: <pi01vs8ftjaglp66gb6mkgei5g4bgj4886@4ax.com>
Hi sso### [at] aolcom, you recently wrote in moray.win:
I'm not sure I understand what shape you want to make, but some things
that may make life easier are:
- Use the local coordinates function to move the pivot point of the
cutting cube to a face. That may make it easier to position.
- Use more than one cube, for example one cube for each plane that you
want to cut away.
- If you know the coordinates of all the points of the final shape,
write a small POV include file and the corresponding UDO and use that.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Subject: Re: geometry - udo.png (0/1)
Date: 20 Oct 2000 17:36:12
Message: <2ae1vso717hg4567egtruuh78k66gasrmq@4ax.com>
Lutz,
Thanks. That helps some, but it is still trial and error.
I have used UDO's in the past by generating the object using a cad
program and importing it in to Moray. However, when you cut a UDO the
light which comes in the hole is visible on the outside of the object.
The picture attached shows a UDO object both with and without a hole
in the far side. As you can see there is a bright patch on the near
side from the light coming through the hole.
I am trying to make the object in the picture using CSG, but figuring
the angles to cut the tapered ends is difficult.
Stefan
Subject: Re: geometry - udo.png (1/1)
Date: 20 Oct 2000 17:36:13
Message: <7le1vsk4v16dcpljq4arl99er63ig9hj7q@4ax.com>
Download 'udo.png' (19 KB)
Preview of image 'udo.png'
