POV-Ray : Newsgroups : povray.unix : PovRay does not start Server Time
20 Apr 2024 06:40:50 EDT (-0400)
  PovRay does not start (Message 1 to 3 of 3)
Subject: PovRay does not start
Date: 18 Mar 2022 10:35:00
Message: <web.623497a958cd70bed40947739db6a733@news.povray.org>
Google translation:
Good morning
PovRay no longer works for me
It gives me the following error:
peter @ peter-ubuntu-nb: ~ $ povray
povray: cannot open the user configuration file
/home/pietro/.povray/3.7/povray.conf: No such file or directory
Problem with option setting
povray
No input file provided
pietro @ pietro-ubuntu-nb: ~ $ povray + I "/ home / pietro / MEGA / System to
create perspectives and axonometries by hand / Guide by line from drawing with
variable arch_asseblato 3D.pov" + W1024 + H736 + AM2 + A + O "/ home / pietro /
MEGA / System to create perspectives and axonometries by hand / Guide by line
for variable arch drawing_asseblato 3D_pov.png"
povray + I / home / pietro / MEGA / System to create perspectives and
axonometries by hand / 3D guide for variable arch drawing_asseblato.pov + W1024
+ H736 + AM2 + A + O / home / pietro / MEGA / System to create Perspectives and
axonometries by hand / Guide by line from drawing with variable arch
Failed to parse command-line option
I also tried creating a link and making an empty povray.conf file:
peter @ peter-ubuntu-nb: ~ $ ln -s / etc / povray / .povray
peter @ peter-ubuntu-nb: ~ $ mkdir -p /home/pietro/.povray/3.7
peter @ peter-ubuntu-nb: ~ $ touch /home/pietro/.povray/3.7/povray.conf
But it still doesn't work
Is there any other way to make it work?
In case I thought I'd try to compile the source files
Pietro
http://creativitainformaticart.altervista.org
Download 'problema avvio povray.png' (149 KB)
Preview of image 'problema avvio povray.png'
Subject: Re: PovRay does not start
Date: 18 Mar 2022 13:30:11
Message: <6234c1a3$1@news.povray.org>
The lack of a valid povray.conf file should not stop a render.
Try:
povray --version
If you get version information povray is running. Then try:
touch void.pov
povray +ivoid.pov
This should render a blank screen and create a blamk void.png file.
I think problem you have is with the spaces in the long file path/name.
In v3.6/v3.7/v3.8 the unix/linux space handling is messed up(a) in a way
which requires weird specifications where spaces are involved.
It should be for v3.7/v3.8 the following works:
touch 'void void.pov'
povray +i \""void void.pov"\"
so long as you otherwise get the file path and name right.
Bill P.
(a) - This oddness is fixed in my povr branch so either of the following
more usual file specifications with spaces work:
povr +i"void void.pov"
or
povr +ivoid\ void.pov
Date: 19 Mar 2022 18:50:00
Message: <web.62365d0ed554561f149546149db6a733@news.povray.org>
Thanks, yes now it works, probably the problem was the spaces in the path names,
I hadn't thought about it or I didn't remember anymore (I had already done some
rendering tests some time ago using FreeCAD and PovRay
https://creativitainformaticart.altervista.org/Prove_FreeCAD_Povray/), I solved
it by replacing the spaces with the crate "_"
