POV-Ray : Newsgroups : povray.tools.general : Pov files into Blender Server Time
24 Apr 2024 03:31:56 EDT (-0400)
  Pov files into Blender (Message 1 to 10 of 14)
Subject: Pov files into Blender
Date: 25 Jan 2022 20:00:00
Message: <web.61f09ca545068dc6b7c8869d4abc77d5@news.povray.org>
is there a way to import povray files into blender? cuz i'm having trouble to
importing it (sorry if it is a bit off topic)
Subject: Re: Pov files into Blender
Date: 26 Jan 2022 04:45:00
Message: <web.61f117fee45a879e16086ed06830a892@news.povray.org>
No problem, yes, there is an importer ; just let me know what doesn't work.
The afore-mentioned icons and workspace tools /tooltips have been added too, if
you get one of the latest builds from here:
https://builder.blender.org/download/daily/
Date: 26 Jan 2022 17:05:00
Message: <web.61f1c466e45a879e41038c8c4abc77d5@news.povray.org>
Am I doing something wrong cuz any file that i import dosen't show up on
blender, is it normal or i'm doing something wrong?
Date: 29 Jan 2022 10:15:00
Message: <web.61f559b3e45a879e34c7846e6830a892@news.povray.org>
Oh! I just made a quick test and it's broken, indeed without any error message,
I have to investigate and will let you know when it's fixed, Thanks for the
report and sorry for the inconvenience.
Date: 30 Jan 2022 18:40:00
Message: <web.61f72066e45a879e34c7846e6830a892@news.povray.org>
Apparently I was a little too brutal in the first step of the - still
ongoing - refactoring, This is now fixed and should be made available in the
next highest numbered build downloadable from
https://builder.blender.org/download/daily/ by tomorrrow. Thanks again for the
report!
Date: 30 Jan 2022 19:50:00
Message: <web.61f7314de45a879e84c7064e4abc77d5@news.povray.org>
> report!
Your welcome
Date: 30 Jan 2022 22:05:00
Message: <web.61f750c9e45a879e84c7064e4abc77d5@news.povray.org>
also what this error means:
Download '' (25 KB)
Preview of image ''
Date: 31 Jan 2022 09:20:00
Message: <web.61f7efd0e45a879e34c7846e6830a892@news.povray.org>
This supposedly means that the file you fed it is not UTF-8 (most standard
international text character set). if that file is available online can you
share / send it ?
Date: 31 Jan 2022 09:30:00
Message: <web.61f7f256e45a879e34c7846e6830a892@news.povray.org>
Otherwise if file is proper utf-8, it could also mean that only path to the file
contains non UTF-8 characters.
Date: 1 Feb 2022 16:55:00
Message: <web.61f9ab39e45a879e34c7846e6830a892@news.povray.org>
> share / send it ?
Never mind : I managed to generate a file that triggered the exact same error to
validate my fix. It should again be available to you tomorrow in that same
place. What the fix does is convert any input file to utf-8 by removing non
utf-8 characters since these generally can't happen in language directive,
rather in user declared names. Which shouldn't be a problem as the alteration
should be quite similar almost everywhere, except when two names differ only by
one different non uniode char in exactly the same place (like e.g. two
accentuated similar words with different accents)
Attached image shows morphine molecule from Avogadro pov output with deliberate
trema accentuated a inside comment, resaved to non utf-8 (nordic) encoding.
Can you try again to import the same file of your own previous attempts to
confirm it at least no longer reports that error?
Download '' (545 KB)
Preview of image ''
