POV-Ray : Newsgroups : povray.unix : povray mode for emacs update? Server Time
29 Mar 2024 06:43:27 EDT (-0400)
  povray mode for emacs update? (Message 1 to 4 of 4)
Subject: povray mode for emacs update?
Date: 14 Oct 2021 09:30:00
Message: <web.61682f654008b668d80ced0afde6c206@news.povray.org>
In lieu of a GUI, some Linux users use Emacs to develop POVray code.
This is greatly facilitated by the povray mode for emacs, the latest version of
which is on Github: https://github.com/melmothx/pov-mode This is written in
emacs Lisp. The text gets color coded, automatic indenting, and general user
friendliness occurs. It even adds a POVray related menu for running the code at
various resolutions. This is effectively close to using a GUI.
This mode works well, even though the last change to this code was
5 years ago, when the keyword for was incorporated.
Unfortunately, another keyword, elseif, has not yet been similarly incorporated.
I posted an issue about this on the Github page a few days ago. It's entirely
possible, even likely, that the current author, melmothx, will respond
eventually. In the meantime I wonder if anyone here would be interested in
taking a look. Or perhaps you could provide a link about emacs Lisp.
Is there some other coding platform which works better for POVray on Linux?
Thanks for any clue.
Subject: Re: povray mode for emacs update?
Date: 14 Oct 2021 10:10:00
Message: <web.616839a5f99d6e745bd1b3ba6cde94f1@news.povray.org>
hi,
not sure about "better", but Vim does a good job syntax-highlighting etc.  Vim
will also use 'tags' files to aid navigation within a project, and I've written
a simple extension to the 'ctags' utility which allows it to parse *.{pov,inc}
files; see thread:
<https://news.povray.org/povray.binaries.utilities/thread/%3Cweb.5e0e133572d06ba48c662f470%40news.povray.org%3E/>
regards, jr.
Date: 14 Oct 2021 12:57:22
Message: <87ee8ny26m.fsf@oook.m.uunet.de>
Jonathan Bush writes:
Guilty, your Honor.  I'm only a casual user of POV-Ray, but a regular
Emacs user (and more software engineer than artist).
I also found a the 'pavement' pattern and the 'albedo' keyword for
diffuse reflection not yet included in the keyword list - but I haven't
done a comprehensive check.  The "Keywords" section in the docs would
provide the relevant test cases, it contains many I've never used and
some I've never heard of.
Adding keywords for highlighting isn't that difficult.  I found the
Emacs Lisp tutorial (comes with Emacs) helpful to get started.
If Marco (melmothx) doesn't reply within decent time, I could give it a
try and provide a pull request for his repository.
Cheers,
haj
Date: 15 Oct 2021 11:15:00
Message: <web.616999c2f99d6e74d80ced0afde6c206@news.povray.org>
Here is a passage with regards to elseif, taken from the changes list at
<http://www.povray.org/download/changes.txt>
Other SDL Changes/Enhancements
  Added #elseif statement; the #if, #ifdef and #ifndef directives syntax is
  changed as follows:
    IF_DIRECTIVE:
      #if ( Cond ) TOKENS... [ELSE_DIRECTIVE] #end
    IFDEF_DIRECTIVE:
      #ifdef ( IDENTIFIER ) TOKENS... [ELSE_DIRECTIVE] #end
    IFNDEF_DIRECTIVE:
      #ifndef ( IDENTIFIER ) TOKENS... [ELSE_DIRECTIVE] #end
    ELSE_DIRECTIVE:
      #else TOKENS... |
      #elseif ( Cond ) TOKENS... [ELSE_DIRECTIVE]
  Example:
    #if (Foo)
      #debug "Foo is true\n"
    #elseif (Bar)
      #debug "Foo is false, but Bar is true\n"
    #else
      #debug "Foo and Bar are both false\n"
> Cheers,
> haj
I am grateful for your offer!
