POV-Ray : Newsgroups : povray.windows : Download Server Time
28 Mar 2024 06:00:39 EDT (-0400)
  Download (Message 1 to 5 of 5)
Subject: Download
Date: 29 Jun 2021 20:05:00
Message: <web.60dbb410816ce026a0e10587b552ed4c@news.povray.org>
Hello,
I heard that you can render transparent backgrounds for images done in VMD. I am
trying to download version 3.6 since I am not sure if the latest version will be
compatible. Everytime I click on the download link nothing shows up; I have
tried to do both x32 and x64 for windows and even tried to download the 3.7
version. My browser does not seem to indicate that a pop-up is being blocked so
I am lost as to why I cannot download the files. Any help would be awesome.
Thanks,
Ray
Subject: Re: Download
Date: 30 Jun 2021 01:02:49
Message: <60dbfaf9$1@news.povray.org>
Am 30.06.2021 um 02:00 schrieb Ray:
> Hello,
I presume you are trying to download from
<https://www.povray.org/download/> and
<https://www.povray.org/download/index-3.6.php>, respectively?
I don't see any immediate issue on our end. Using Firefox 89.0.2
(64-Bit), I can download the .MSI installer files for both the 32-Bit
and 64-Bit versions of POV-Ray v3.6.2.
In case something about the redirect is putting your browser off, you
could try downloading directly from the FTP server:
https://www.povray.org/ftp/pub/povray/
If that also doesn't work, you could try downloading POV-Ray v3.7.0 from
GitHub:
https://github.com/POV-Ray/povray/releases/tag/v3.7.0.0
Date: 30 Jun 2021 08:40:30
Message: <60dc663e@news.povray.org>
I had a look at this also and did notice one thing: at least in Firefox,
the FTP download links (present on the v3.6 page but not used for 3.7)
don't work anymore. FTP is deprecated in v89 and will be removed
entirely in v90. Chrome appears to have already turned it off by default.
The FTP download links were a bit of a relic of a past age when dialup
was the norm and a FTP connection was a little more stable than HTTP, so
they're not really needed. Accordingly I've removed them (but kept a
reference to the FTP server for those who want to use it).
Not sure if this was the issue facing Ray but thought it worth mentioning.
-- Chris
Date: 30 Jun 2021 11:02:44
Message: <60dc8794$1@news.povray.org>
> Hello,
> Thanks,
> Ray
Unless your computer is very old with a very old OS, you should get
version 3.7. By very old, I mean Pentium 3 or earlier running Windows ME
or earlier.
If you have a multicore CPU, then, you should definitively get version
3.7, as version 3.6 can only use a single core.
If your OS is 64 bits, then, get the 64 bits version.
Date: 30 Jun 2021 12:00:00
Message: <web.60dc94a29378979b22dd578ab552ed4c@news.povray.org>
> -- Chris
Hello Chris,
Yeah that seems to be the issue. I should have mentioned that I was using chrome
as the default browser.
Thanks
