POV-Ray : Newsgroups : povray.tools.general : WIP Blender addon test files Server Time
25 Apr 2024 04:47:32 EDT (-0400)
  WIP Blender addon test files (Message 1 to 2 of 2)
Subject: WIP Blender addon test files
Date: 8 Jun 2021 19:35:00
Message: <web.60bffdbe542164416086ed03f378f2@news.povray.org>
Good evening / good day
I would like to create a couple of test files for the Blender addon. ideally
they would have to look nice and render fast. So this is a first step in the
first file, which renders really slowly. I guess there's room for improvement if
we set the anti aliasing to method 2 (stochastic) since the scene uses aperture
(camera depth of field)... But I'd rather wait for a couple of crossplatform
builds of v3.8 to be available before switching this option on. Meanwhile I
believe there could be more tweaks already available in version 3.7 that could
improve render time at not too high of a quality expense ?  Some more seasoned
users will probably spot bad defaults or wrong options to modify from the
scene's statistics below before next iteration? thanks in advance !
Parser Statistics
Finite Objects:          129
Infinite Objects:          0
Light Sources:             1
Total:                   130
BSP Split Nodes:         295
BSP Object Nodes:        280
BSP Empty Nodes:          16
BSP Total Nodes:         591
BSP Objects/Node Average:           3.59          Maximum:              15
BSP Tree Depth Average:            12.34          Maximum:              18
BSP Max Depth Stopped Nodes:           0 (0.0%)   Objects/Node:       0.00
Parser Time
  Parse Time:       0 hours  0 minutes  5 seconds (5.937 seconds)
              using 1 thread(s) with 5.928 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 2, Threshold 0.030, Depth 1, Jitter Off,
 Gamma 2.50)
Render Statistics
Image Resolution 960 x 540
Pixels:           553521   Samples:               0   Smpls/Pxl: 0.00
Rays:            8985915   Saved:            258762   Max Level: 4/4
Ray->Shape Intersection          Tests       Succeeded  Percentage
Mesh                      217718609382     97646791188     44.85
Sphere                      1402839410               0      0.00
Bounding Box             4414078518151   1486363038246     33.67
Shadow Ray Tests:       83585871495   Succeeded:           34847860902
Shadow Cache Hits:      29816821261
Reflected Rays:             3921023   Total Internal:            83274
Refracted Rays:             1187575
Radiosity samples calculated:               89 (0.00 %)
Radiosity samples reused:             23190843
Radiosity sample rays shot:               2670
Radiosity octree nodes:                     24
Radiosity octree samples/node:            3.71
Radiosity blocks examined:          1543170794
Radiosity blocks passed test 0:     1543170794 (100.00 %)
Radiosity blocks passed test 1:      829683772 (53.76 %)
Radiosity blocks passed test 2:      555680174 (36.01 %)
Radiosity blocks passed test 3:      357767513 (23.18 %)
Radiosity blocks passed test 4:      310127134 (20.10 %)
Radiosity blocks passed test 5:      295010649 (19.12 %)
Radiosity blocks rejected:          1248160145 (80.88 %)
Radiosity Depth 0 calculated:               89 (0.00 %)
Radiosity Depth 0 reused:             23190843
Radiosity Depth 0 rays shot:              2670
Radiosity (final) calculated:               33 (0.00 %)
Radiosity (final) reused:             23106413
Radiosity (final) rays shot:               990
  Pass     Depth 0           Total
  1             23              23
  2             19              19
  3             14              14
  Final         33              33
  Total         89              89
  Weight     0.102
Peak memory used:         166371328 bytes
Render Time:
  Photon Time:      No photons
  Radiosity Time:   0 hours  1 minutes 57 seconds (117.198 seconds)
              using 8 thread(s) with 792.966 CPU-seconds total
  Trace Time:       7 hours 51 minutes 48 seconds (28308.650 seconds)
              using 8 thread(s) with 210100.333 CPU-seconds total
Download 'bmwwipa_07-54-03.png' (452 KB)
Preview of image 'bmwwipa_07-54-03.png'
Subject: Re: WIP Blender addon test files
Date: 8 Jun 2021 20:20:00
Message: <web.60c00846f64e033216086ed03f378f2@news.povray.org>
* Source is an original model by Mike Pan under CC0 licence ! Thanks !
