POV-Ray : Newsgroups : povray.macintosh : [Q] POV-Ray in command line Server Time
25 Apr 2024 17:58:04 EDT (-0400)
  [Q] POV-Ray in command line (Message 1 to 10 of 37)
Subject: [Q] POV-Ray in command line
Date: 27 Jan 2021 10:30:08
Message: <60118700$1@news.povray.org>
I use POV-Ray in command line under macOS Catalina and Macports,
and run it about 2000 times, in order to render 2000 images. My
issue is when you launch `povray` in command line, it opens a
menu bar, and displays an icon in the macOS dock ...
Is there a command line option, that prevents POV-Ray from displaying
a menu bar and an icon in the dock ? Because when you launch it 2000
times, for 2000 images, the Apple Finder and the Macintosh become
unusable ... The computer keeps displaying the bar and the icon,
and you can't do anything else with the Macintosh. You have to wait
that the 2000 images are rendered ... You have to wait half an hour,
so that POV-Ray stops rendering.
There must be a solution. Because you can't do anything else, before
POV-Ray has stopped rendering ... This is very painful ...
Thanks for any help.
Best regards,
<http://eureka.atari.org/>
Subject: Re: [Q] POV-Ray in command line
Date: 28 Jan 2021 08:16:49
Message: <6012b941$1@news.povray.org>
On 1/27/21 10:30 AM, Francois LE COAT wrote:
> Hi,
Unsure if true with the macOS version you are running, but with
Linux/Unix versions (which only display an icon) you can use '-d' to not
create a preview display and icon or '--preview text' (or '-y text) to
use the inbuilt text only mode.
Bill P.
Date: 28 Jan 2021 11:05:02
Message: <6012e0ae$1@news.povray.org>
William F Pokorny writes:
t
> Bill P.
My .INI file is :
All_Console=Off
Antialias=On
Bounding_Threshold=3
Continue_Trace=Off
Display=Off
Draw_Vistas=On
Height=640
Input_File_Name="./pacman_mod.pov"
Library_Path="/usr/share/povray-3.7"
Library_Path="/usr/share/povray-3.7/ini"
Library_Path="/usr/share/povray-3.7/include"
Library_Path="/usr/local/share/povray-3.7"
Library_Path="/usr/local/share/povray-3.7/ini"
Library_Path="/usr/local/share/povray-3.7/include"
Output_File_Name="./pacman.png"
Output_File_Type=N
Output_To_File=On
Split_Unions=On
Test_Abort=Off
Verbose=On
Width=640
Work_Threads=12
I don't know how I should modify it, so that is doesn't use a menu bar,
and show an icon in the macOS dock. "Display=Off" is set, so what shoul
d
I do more ? I want POV-Ray to be quiet ... The menu bar and icon are
embarrassing. That prevents from using anything else than POV-Ray :-(
Thanks for your help.
Date: 28 Jan 2021 13:37:00
Message: <6013044c$1@news.povray.org>
Hello,
you need to find out who created that port and figure out what they did.
The regular Unix code does not create any menu bar or icon because it
simply knows nothing about Mac OS X.
The other thing is that you should not be starting 2000 instances of
POV-Ray at the same time...
Thorsten
>> not create a preview display and icon or '--preview text' (or '-y
>> text) to use the inbuilt text only mode.
> and show an icon in the macOS dock. "Display=Off" is set, so what should
Date: 28 Jan 2021 15:38:35
Message: <601320cb@news.povray.org>
Thorsten writes:
That's the POV_Ray port available in Macports for macOS Catalina :
	<https://ports.macports.org/port/povray/>
I'd better build POV_Ray myself, what I already done, if there's no
peculiar option to suppress usage of the menu bar, and dock's icon.
I launch POV_Ray about 2000 times, one after the other, with the use
of 12 threads (the Macintosh has 9 cores), and I must do something
else in between, because the Mac is completely monopolized. I can't
even read my email, because the Finder's interface becomes a mess ...
It's really curious that no Mac user ever noticed that peculiarity
of the Macports version. There must not be a lot of users like me :-)
g
ould
Date: 28 Jan 2021 15:40:46
Message: <6013214e$1@news.povray.org>
On 1/28/21 1:37 PM, Thorsten wrote:
> Hello,
> Thorsten
I agree with Thorsten that finding the author of your particular port
and asking them whether one can suppress the menu bar and icon may
ultimately be your only option.
That said, people doing mac ports have posted unix/linux build issues to
github - so some are using the shipped unix/linux build system. You have
the display off - good. Somewhere you are issuing a command line like:
povray your.ini ...
It's a shot in the dark, but add '--preview text' to the command line
and see if that helps... Try first running a single job with that
command line. It's a unix/linux only option and not an ini settable one.
If it isn't supported / doesn't work, it should be immediately obvious
from one render.
Agree too that, if you are submitting 2000 jobs at once, that's likely
as much the issue with usability as anything. Funneling jobs in over
time would be better and doing that in a way tied to the availability of
system resources best. I'd taken what you said to be 2000 jobs one after
another over 30 minutes (<1s a render).
And a clarification to what Thorsten said about icons and POV-Ray as
shipped. On unix/linux, if you are running a window manager which looks
to generate icons from opening X11 windows, you do get them unless you
override default(s).
Bill P.
Date: 28 Jan 2021 16:10:39
Message: <6013284f@news.povray.org>
>> did. The regular Unix code does not create any menu bar or icon
>> because it simply knows nothing about Mac OS X.
r,
hould
o
e
> povray your.ini ...
> from one render.
If I launch "%povray --preview text pacman.ini" in command line I have :
povray: cannot open the user configuration file
/Users/admin/.povray/3.7/povray.conf: No such file or directory
Problem with option setting
Failed to parse command-line option
That doesn't work. Do you have an advice ?
Thanks,
Date: 28 Jan 2021 23:30:01
Message: <web.60138e02b3a558266396ca3e0@news.povray.org>
I don't have a solution to your finder problem but I thought a work around could
be to render your 2000 images as if it was an animation. Then you would launch
only one instance of Pov-ray (I think, not completely sure actually how it works
on Mac). Yet, I don't know if you could easily change your
script to render the appropriate image based on the clock variable...
Pascal
Francois LE COAT <lec### [at] atariorg> wrote:
> Hi,
> Best regards,
Date: 29 Jan 2021 04:22:13
Message: <6013d3c5$1@news.povray.org>
On 1/28/21 4:10 PM, Francois LE COAT wrote:
> Hi,
My last two ideas. First, the sort of advice jr gives me. Have you tried
just:
povray --help
at a command line? I don't hold out much hope, but maybe it would kick
out any extra command line flags that are supported. It's what the
straight unix/linux compile does.
And second, an idea more complicated. With X11 at least there is a null
display utility usually used for testing. I can't remember the name...
Ah, it's xvfb. I've never used it myself only hearing someone else
mention it long ago. Looks like it can be installed on Ubuntu 20.04, but
no idea if you have anything similar on macOS?
Aside: I think that configuration file message is another issue and not
critical.
Bill P.
Date: 29 Jan 2021 05:40:01
Message: <web.6013e576b3a5582679819d980@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> My last two ideas. First, the sort of advice jr gives me. ...
</grin>  reminds me I meant to post re your comment (in another thread) that
'vim' has become your day-to-day editor.  first, if you want the '#for()' to
indent properly, add it to the list in line 63 of
'/usr/share/vim/vim81/indent/pov.vim'.  second, I recently "discovered" vim's
folding capabilities, great stuff, check it out (I added 'set foldmethod=marker'
in the '~/.vimrc', works equally well with Tcl.  :-))
regards, jr.
