POV-Ray : Newsgroups : povray.advanced-users : Color maps Server Time
18 Apr 2024 01:26:08 EDT (-0400)
  Color maps (Message 1 to 7 of 7)
Subject: Color maps
Date: 21 Mar 2021 09:56:59
Message: <605750ab$1@news.povray.org>
So, I have been working with functions and patterns for a while now, and
aside from not having vector functions to easily create color values
with, I have run into an issue with the way POV-Ray maps things -
colors, pigments, textures.
Since I haven't experimented extensively with these mapping mechanisms
or gone through the source code to see exactly how they are handled, I
as far as I know, they only handle values in the range from zero to one.
I'm interested in knowing if anyone has done any work that contradicts
this notion, or to hear how I might use negative numbers, large numbers,
or ways to get around the auto-wrapping-around of the color map.  I'd
like to subtract part of one color channel from the overall result of an
average {} pigment using a negative value, or saturate the color (to
white) by allowing large values.
Any data would be helpful.
Thanks!
Subject: Re: Color maps
Date: 22 Mar 2021 07:27:30
Message: <60587f22$1@news.povray.org>
> Thanks!
The short answer if you are using v3.7 or v3.8 more or less stock, is
you can use the 0-1 map range only(1).
(1) - And even with this there are some general issues/bugs.
For more information look at the series of postings working backward
from to the first few starting here:
http://news.povray.org/povray.beta-test.binaries/thread/%3C5fdfc14f%40news.povray.org%3E/
Bill P.
Date: 23 Mar 2021 14:06:08
Message: <605a2e10$1@news.povray.org>
That's what I thought.
Any chances on future alternate mechanism for color/pattern/texture
mapping in POV-Ray or povr?
I hadn't known.  :O
No idea what you're directing me to.  But I will make do with 0-1.
Could I fake/simulate a wider range using an attenuated function output
coupled with a color map ranging from negative color values to color
values above 1?
Do you know where the "color math" happens in source?   I'm wondering if
it's as simple as summing the rgb values.
Does <-n, 1, 1> = <0, 1-n, 1-n>?
And how do HDRI ... things ... get encoded?
Date: 24 Mar 2021 06:20:42
Message: <605b127a$1@news.povray.org>
In my povr branch, extensions, yes.
Therein I've as much been clearing issues as adding function. The core
map mechanism itself doesn't care what the map range is. It's the wave
modifier functionality and the "bridge code" between pattern(s) /
function(s) and the map mechanism which have limits <= v3.8 today. Some
of these bridge limitations enabling real issues in current patterns to
go 'mostly' unnoticed.
> I hadn't known.  :O
A collection of posts with my ramblings on some of the issues and
proposed changes/fixes - raw_wave, function_interval, etc. - which I'm
giving a go in my povr branch.
Partly, these some answer to your last offline question regarding links
related to working with functions.
> values above 1?
Yep, probably so... We have functions v3.5 on. You 'can' do a lot from
that point onward working around the 'gotchas'. Whether easy or
efficient to do is another question - as you know. :-)
./source/base/image/colourspace.* ./source/base/colour.* has a lot of
it. I have no complete list.
Posted very recently some details on this elsewhere. :-) I only just
figured this question out myself while otherwise chasing a ghost-bug
really my own doing...
The hdr format uses rgbe and exr uses half floats (16 bits) making both
useful ONLY for dynamic range images and light / environment maps.
I've tossed a good chunk of time in the bit bucket trying to use our exr
implementation as a deep bit per channel format due not really
understanding POV-Ray's implementations... :-(
Aside:
I've started to look at adding the .pfm/pfm(extended) format (32 bit
floats per channel) as another image file type in my povr branch.  It's
supported by quite a few tools (like gimp). It's simple. It's been
around a long time. However, it's not all that far up on my to-do list
at the moment due having new inbuilt functions in povr which can do deep
bit in existing formats using multiple channels.
There, though, I've since found some issues in the ppm/png formats (of
v3.8) if using other than linear encoding/decoding of those images.
Still not sorted everything with png and it's the format I'd most want
to use due the non-lossy compression.
Anyway... Onward! :-)
Bill P.
Date: 24 Mar 2021 06:56:30
Message: <605b1ade$1@news.povray.org>
Ah, ok.  That's the part I was missing.  I thought maybe it was a
#if (PointE > 1)
#declare PointE = 0
Sort of thing.
I just did a bunch of function/pattern work, and I think I know what
you're talking about.  Which patterns have the hidden problems?  Part of
what I'm doing is discussing how POV-Ray generates and uses its
patterns, so I could weave that into what I already have, and maybe
knowing what the underlying problems are, the ole' brain might come up
with something - - - when I'm _trying_ to sleep.   ;)
Ah, right.  Thanks for the reminder.
Have you looked at .raw?  I know next to nothing about it except that it
seemed flexible, was used for ultra high-end digital cameras, and you
can jam a whole lot of information into it besides the image data.
> Bill P.
Indeed.   Ever onward.
- and -
If you ever have ramblings on the C / C++ code you're writing, I'd be
interested in reading that - maybe in the programming section.
Thanks for the info as always
Date: 24 Mar 2021 20:04:52
Message: <605bd3a4$1@news.povray.org>
> Bill P.
Thought I'd check Warp's site - it's defunct.
archive.org has a snapshot.
He's got a git
https://github.com/WarpRules/WPngImage
Maybe you'd be interested in that library - might hold some clues.
Date: 25 Mar 2021 02:02:28
Message: <605c2774$1@news.povray.org>
>> Bill P.
> He's got a git
Thanks for the pointer. I wasn't aware of his work there.
On .raw support not looked much at it because it isn't that deep per
channel bit wise at 12-14 bits usually(1), but might still be useful to
support I guess.
(1) - Not that experienced with .raw myself, but the high dynamic range
is often achieved with bracketed exposures I believe. Been away from the
details of digital cameras for a while though.
With Warp's library though I wonder, if we are looking to make larger
image io / color support changes, whether POV-Ray shouldn't be looking
at all the work under the https://www.aswf.io/# umbrella.
I believe Blender not that long ago moved to those libraries for much
(all?) of their image and color space support. We might for example get
icc png profile support for 'free' - so to speak - using it, where
POV-Ray doesn't support such things today.
If just 32 bit floats / channel max as I expect, it might still be
limited for some of the function related stuff we've been playing with.
In other words, even with it we might want a little more.
There is too netpbm's .pam format - a form of which can be used almost
directly for df3 files.
:-) All sorts of stuff possible.
Bill P.
