POV-Ray : Newsgroups : povray.text.scene-files : Lens flare macro not working Server Time
29 Mar 2024 04:27:19 EDT (-0400)
  Lens flare macro not working (Message 1 to 6 of 6)
Subject: Lens flare macro not working
Date: 17 Feb 2021 23:41:50
Message: <602df00e$1@news.povray.org>
I am unable to get the lens flare macro to show up in the attached
scene. What am I doing wrong?
It's a 6 frame animation. The lens flare should appear over the sun in
frame 3 out of 6.
Thank you.
Mike
Download 'lens_flare_test.pov.txt' (4 KB)
Subject: Re: Lens flare macro not working
Date: 18 Feb 2021 17:00:00
Message: <web.602ee2613841873bd98418910@news.povray.org>
At first, I thought the code was only producing a 5-frame animation, then
crasing on frame 6-- until I changed my INI file's animation setting to
Initial_Frame=0  ;-)  I usually start at 1, the default.
I do see a tiny planet sphere on frame 3-- but I had to comment-out your
        #include Lens_Mod.inc
to get the scene to run, as that include file is not part of Chris Colefax's
Lens Flare macros at
      http://www.oocities.org/ccolefax/lenseffects.html
I don't have CIE.inc or lightsys.inc, so I ran the scene without those. I assume
that they are not necessary for the lens flare effect(?)
Date: 18 Feb 2021 17:35:01
Message: <web.602eeac43841873bd98418910@news.povray.org>
> Lens Flare macros...
I replaced that .inc file with Chris's LNSEFCTS.inc ; maybe that's what you
meant to #include?
Now, on frame 3, the render turns pure white. Is that what you're seeing as
well?
Date: 19 Feb 2021 20:06:49
Message: <603060a9$1@news.povray.org>
> meant to #include?
> well?
Sorry about that.
I think you're supposed to replace it with LENS.INC.
I don't get a white screen.
Mike
Date: 19 Feb 2021 20:08:57
Message: <60306129$1@news.povray.org>
You are correct.
Mike
Date: 20 Feb 2021 01:14:01
Message: <6030a8a9$1@news.povray.org>
>>> Colefax's
>> what you
>> meant to #include?
>> seeing as
>> well?
> Sorry about that.
> Mike
The problem was with the camera code. I had the Camera_Location and
Camera_LookAt set incorrectly.
Mike
