POV-Ray : Newsgroups : povray.windows : Win7x64: Uninstalled POV 3.62, can no longer associate INC files with POV 3= Server Time
11 May 2025 08:39:52 EDT (-0400)
  Win7x64: Uninstalled POV 3.62, can no longer associate INC files with POV 3= (Message 1 to 7 of 7)
Subject: Win7x64: Uninstalled POV 3.62, can no longer associate INC files with POV 3=
Date: 4 Jan 2014 22:15:01
Message: <web.52c8cd4dc4453b00f5699ff20@news.povray.org>
Formerly I had POV 3.62 and 3.7 both installed on the same machine. I switched
over to 3.7 exclusively.
However, now I cannot associate INC files with POV-Ray on Windows 7 x64. I can
navigate to the program through the "Open File" dialog, but the association does
not "stick". I.e. it is simply ignored/reset back to the earlier program, in my
case Notepad.
Does anyone have any tips on how to resolve this?
Subject: Re: Win7x64: Uninstalled POV 3.62, can no longer associate INC files with POV 3=
Date: 5 Jan 2014 01:46:46
Message: <52c8ffd6$1@news.povray.org>
> case Notepad.
Have you tried, select the *.pov file, right click, open with, "choose
default program"?
Regards
Subject: Re: Win7x64: Uninstalled POV 3.62, can no longer associate INC files with P=
Date: 5 Jan 2014 09:05:00
Message: <web.52c96605250e988df5699ff20@news.povray.org>
> default program"?
> Regards
>      Stephen
Yes, the POV files are properly associated with POV 3.7. It is the INC files
that are not working.
Mike
Date: 5 Jan 2014 10:54:05
Message: <52c9801d@news.povray.org>
>> default program"?
>> Regards
>>       Stephen
It would be the same procedure with *.inc files. Remember to tick the
box that says. "Always use the selected program to open this kind of file."
Or you could hack the registry.
Regards
Date: 5 Jan 2014 20:20:01
Message: <web.52ca047b7db1c401f5699ff20@news.povray.org>
Yes, I did this. I am able to set the file association for other programs, like
Notepad++. But it fails to "stick" when trying to do the same for any of
POV-Ray's executables.
> Regards
>      Stephen
I would like to confirm whether this is a bug or not before seeking alternative
solutions.
Mike
Date: 5 Jan 2014 20:50:01
Message: <web.52ca0b7c7db1c401f5699ff20@news.povray.org>
> solutions.
> Mike
Update: I was able to set the association with the SSE2 Win32 version, but not
pvengine64.exe or pvengine.exe.
I'm going to keep searching for a solution involving editing the registry.
Mike
Date: 5 Jan 2014 21:05:00
Message: <web.52ca0e597db1c401f5699ff20@news.povray.org>
I found the issue and the solution to the issue here:
http://answers.microsoft.com/en-us/windows/forum/windows_7-files/problems-with-file-association-in-windows-7-64-bit/8a8
4fcec-22df-4942-8e35-d98dbe96e327
POV-Ray 3.7 wasn't registered correctly. The registry key discussed in the
article was associated with POV 3.62 instead of 3.7.
Mike
