POV-Ray : Newsgroups : povray.windows : Rendering 20500 POV Files Server Time
19 Apr 2026 05:55:02 EDT (-0400)
  Rendering 20500 POV Files (Message 1 to 10 of 15)
Subject: Rendering 20500 POV Files
Date: 25 Jul 2013 16:05:01
Message: <web.51f184ded8de8676af3d580b0@news.povray.org>
  I have 20500 frames written from a molecular dynamics simulation. Is there
anyway to easily render these is batch (I believe the queue will only allow 512
files at the moment). Other than staying up all night and re-filling the queue
when it empties, the only way I can think to do this currently would be to load
up
40 instances of POV ray... each with a full queue and start them
simultaneously!... guessing that's not the best option!
Any suggestions?
Thanks in advance,
Peter
Subject: Re: Rendering 20500 POV Files
Date: 25 Jul 2013 17:25:00
Message: <web.51f1972722430c8aae2fd8290@news.povray.org>
"Peter" <mur### [at] gmailcom> wrote:
> Any suggestions?
> Thanks in advance,
> Peter
 Write a bat file that you can run from cmd.exe
Use an external text editor or write a macro in povray to generate it as a ascii
text file
B.Gimeno
Date: 25 Jul 2013 18:40:01
Message: <web.51f1a82c22430c8aaf3d580b0@news.povray.org>
Been a while since I've had to use them... didn't even think of using that..
I'll give that a try!
Thanks.
peter
Date: 25 Jul 2013 21:16:24
Message: <51f1cde8$1@news.povray.org>
> Hi,
> up
> Any suggestions?
> Thanks in advance,
> Peter
Are your source files ending in sequential numbers?
If so, you can use the internal animation feature to render all your
frames within a single sequence.
You can have a main .POV file that will #include the relevent data
according to the frame_number value using some string manipulations. The
concat(...) and str(...) string functions will greatly help construct
the needed files names.
#declare IN_File = concat("Mole",str(frame_number, -5, 0), ".inc")
#include IN_File
The "-5" in str mean zero-pading of the value to 5 digits.
The "0" means zero decimal places.
And start the render with +kff 20500 on the command line.
This assume that your molecule are described in files names "Molexxxxx.inx".
Change the name as needed.
You can include files with any extention as long as they are writen
using the correct POV syntaxe.
Date: 26 Jul 2013 14:30:00
Message: <web.51f2bf1122430c8aaf3d580b0@news.povray.org>
Yes... they are animate00000.pov - animate20500.pov
> #include IN_File
I have created a POV file with this as its contents (based on your suggestions
above):
#declare IN_File = concat("animate",str(frame_number, -5, 0), ".pov")
#include IN_File
However, when I run from the command line, nothing happens. When I run it using
the GUI I get an error "Parse Error: Cannot open animate00000.pov" .
This would suggest (to me at least) that the animate00000.pov is not readable,
however, I know this isn't the case since I have rendered many of the files
individually and using the queue (and a batch file) and they are fine.
Am i missing something?
Peter
Date: 26 Jul 2013 15:31:54
Message: <51f2ceaa$1@news.povray.org>
A silly question but are your files in the same directory as the master
file?
This is an example that works for me.
#include concat("f:\\Graphics\\B3D
Data\\Scenes\\Earth_Inside\\Chain02G1\\Chain02G2Y_",str(mod(frame_number,89),-4,0),".pov")
Regards
Date: 26 Jul 2013 15:55:00
Message: <web.51f2d32b22430c8aaf3d580b0@news.povray.org>
> file?
Yes.. they are in the same directory... but I suppose you had to ask that!! :P
> Regards
>      Stephen
I'll update my file and give it a try. I have gotten a batch file working, but
the way its set up right now I have POV ray opening, rendering a scene (~1.7
seconds) and closing... then repeating over and over and over again.... besides
the risk of epileptic seizure, it would obviously be faster to either keep one
POV ray open and one after another pass the 20501 files through to be rendered
or to have pov-ray start minimized... at least that way the render time would be
decreased and I wouldn't have windows flashing every 1-2 seconds!
Date: 26 Jul 2013 16:00:01
Message: <web.51f2d4a822430c8aaf3d580b0@news.povray.org>
> file?
> Regards
>      Stephen
So... you were right to ask about the files being int he same directory... I
didn't make that stupid mistake, but I realized once I saw your code Chain02G2Y_
(with the _ that my filenames are actually animate.XXXXX.pov not
animateXXXXX.pov!! seems to work now!!
Thanks for all of your help everyone!!
Date: 26 Jul 2013 17:01:13
Message: <51f2e399$1@news.povray.org>
On 26/07/2013 8:57 PM, Peter wrote:
> I
Don't ask me how many times I've made that mistake. :-)
I generally use a #debug to print to screen what the code is writing.
Good for catching spaces as well.
Regards
Date: 26 Jul 2013 17:21:48
Message: <51f2e86c$1@news.povray.org>
There is a better way than running the files sequentially. You can use
the animation feature. Here is a snipit of code from an ini file.
Input_File_Name = animate_.pov
Output_File_Name = animate_
Initial_Frame = 0
Final_Frame = 999999
Subset_Start_Frame = 0
Subset_End_Frame = 20501
  /* I like to use an underscore between the name and the numbers for
readability. */
"Input_File_Name" calls your PovRay master file (which #includes your
series of pov files"
"Output_File_Name" is the base name of the rendered files.
"Initial_Frame": Your start frame number. (Keep it 0)
"Final_Frame" : Any number bigger than your largest frame number.
"Subset_Start_Frame": Where you want to start rendering from.
"Subset_End_Frame": Where you want to stop rendering.
You don't need to use an ini file. You can use command line options.
This method works for me.
Regards
