POV-Ray : Newsgroups : povray.windows : Looking for a way to disable POV-Ray for Windows splash screen Server Time
11 May 2025 08:43:10 EDT (-0400)
  Looking for a way to disable POV-Ray for Windows splash screen (Message 1 to 5 of 5)
Subject: Looking for a way to disable POV-Ray for Windows splash screen
Date: 26 Feb 2013 13:50:01
Message: <web.512d039ae09b06803693283d0@news.povray.org>
my application uses POV-Ray for rendering, so my users first install POV-Ray and
then run my application.
What happens often and leads to complaints is that users run my application at
work, go home, and when they come back the next morning, the work has not been
completed. Instead everything hangs at POV-Ray, which shows a Windows welcome
splash screen and waits for the user to click a button.
So it appears that the first time you run POV-Ray after installing it, you need
to press a button. Is there any way to disable this behavior? How does POV-Ray
remember that it has been run once already? Can I maybe change a registry entry
or similar from my application?
Thanks for your help,
Elmar
Subject: Re: Looking for a way to disable POV-Ray for Windows splash screen
Date: 26 Feb 2013 15:02:29
Message: <512d14d5@news.povray.org>
> Hi,
> Elmar
In "pvengine.ini", you have:
[General]
RunCount=484
This tels you how many times POV-Ray have been started.
Toward the end of the file, you find this section:
[DontShowAgain]
All items set to 1 will not be shown.
Date: 10 Mar 2013 13:20:01
Message: <web.513cbff08e0bb3ea9068eaa80@news.povray.org>
Hi Alain,
merci bien for your quick reply and the hint to look at pvengine.ini
Here is what I did in Windows 7, 64bit:
1) Use the start menu to look for pvengine.ini, which was found in
c:\Users\elmar\Documents\POVRay\v3.6\pvengine.ini
2) Uninstall and reinstall POVRay 3.6.1 to determine when this file is actually
created so that my application can modify it.
3) Interestingly, when my application now started POVRay, POVRay did *not* wait
for a key to be pressed. And it *did not* create a new
c:\Users\elmar\Documents\POVRay, so there is now no private pvengine.ini I could
modify.
4) I only found a PVENGINE.INI in POVRay's installation directory. When I tried
to modify it with Notepad, I got "access denied". When I ran Notepad as
administrator, I could change RunCount=0, but again, POVRay did not ask for a
keypress. Also I noted that RunCount=0 stays unchanged, no matter how often I
run POVRay. An application can normally not modify data in its own install
directory, so I guess it's expected that RunCount=0 stays that way forever...?
Here is the PVENGINE.INI from POVRay's install directory:
[Permitted Input Paths]
1=%INSTALLDIR%
2=C:\Windows\Fonts
2=%FONTDIR%
[Permitted Output Paths]
1=%INSTALLDIR%\Renderer\ReRun
2=%INSTALLDIR%\Insert Menu
[General]
AutoAppendPaths=1
BigSplash=1362934629
RunCount=0
[General]
CheckNewVersion=0
SendSystemInfo=0
[Editor]
LastPath=C:\PROGRAM FILES (X86)\POV-RAY FOR WINDOWS V3.6\SCENES\ADVANCED
[Info]
Rendering=0
[LastRender]
CurrentDirectory=C:\Program Files\yasara\tst
So I guess, the open question is: where is the pvengine.ini to modify, and how
can I modify it before running POVRay the first time? (I would expect that
POVRay creates the file the first time it's run, but then it's already too
late).
Many thanks for your help,
Elmar
> > Hi,
> > Elmar
> [General]
> RunCount=484
> [DontShowAgain]
> Alain
Date: 10 Mar 2013 21:32:03
Message: <513d3413@news.povray.org>
You may wish to try 3.6.2 instead. I think that version
introduced the updated directory / file handling regarding
the UAC access restriction in Windows Vista / 7.
Date: 11 Mar 2013 05:19:08
Message: <513da18c@news.povray.org>
Am 11.03.2013 02:32, schrieb Christian Froeschlin:
>> actually
Indeed. As a matter of fact, improved compatibility of the 3.6 branch
with Vista was the only motivation for the 3.6.2 release. (Consequently
there's no 3.6.2 for Linux, BTW.)
