POV-Ray : Newsgroups : povray.windows : Cannot find INI file Server Time
1 Apr 2026 10:58:24 EDT (-0400)
  Cannot find INI file (Message 1 to 2 of 2)
Subject: Cannot find INI file
Date: 5 Jul 2012 07:55:01
Message: <web.4ff57fd2363bb61d6a57af450@news.povray.org>
I am using Povray via the command line from my Euler (euler.rene-grothmann.de)
program. The command line is the following
pvengine.exe /NR /EXIT +H450 +W450 +FN24 +A -D /RENDER
"c:\Users\Rene\Euler\current.pov"
"pvengine.exe" is in the path. The command is called with CreateProcess. This
works well in Windows 7. It renders the file and, since I set the current
directory properly, I can find the PNG output.
However, it does not work in Windows XP. The Povray program opens and does
nothing. If I open the pov file there, and try to run it it says INI file not
found. If I try to run this from a command line, it says INI file not found
right away. If I open Povray with the provided Windows icon and load the file,
it works.
So how can I direct Povray with a command line to find the INI files?
Thanks for assistance,
R.G.
Subject: Re: Cannot find INI file
Date: 5 Jul 2012 08:55:00
Message: <web.4ff58e96a710e2026a57af450@news.povray.org>
Sorry, I found the problem already.
I had two versions of Povray on my computer, and was running the old one, while
I wanted to run the new one. Maybe the old one cannot use the new ini files?
After uninstalling everything and deleting the directory, and after a new
install, everything worked as expected.
R.G.
