POV-Ray : Newsgroups : povray.windows : Another reason to hate Windows 7 Server Time
4 Feb 2026 23:24:35 EST (-0500)
  Another reason to hate Windows 7 (Message 1 to 10 of 42)
Subject: Another reason to hate Windows 7
Date: 27 Sep 2011 15:00:00
Message: <web.4e821ce3dda7995285de7b680@news.povray.org>
I start an overnight render.  I wake up the next morning, expecting a beautiful,
polished image.
Instead, the damn machine has gone into sleep mode!
Sleep mode is good. It saves power.
BUT NOT WHILE THE COMPUTER IS IN THE MIDDLE OF A TASK.
Someone recently mentioned the principle of least surprise in p.o-t.  Micro$hit
seems adamantly opposed to the whole concept.
Subject: Re: Another reason to hate Windows 7
Date: 27 Sep 2011 16:36:19
Message: <4e8233c3@news.povray.org>
  And I assume there's no way of saying "don't go to sleep mode if this
program is running"? Or even "don't go to sleep mode if there's significant
CPU activity"?
  OTOH, probably no OS has such a feature (at least not out-of-the-box,
easily selectable via GUI).
Date: 27 Sep 2011 16:48:40
Message: <4e8236a8@news.povray.org>
> polished image.
One of the first thing I do on a freshly installed/new computer it to
set it as a presentation machine. This effectively disable automatic
sleep mode.
Date: 27 Sep 2011 17:10:18
Message: <4e823bba$1@news.povray.org>
Create a custom Power Plan to use when rendering when the 'putor never
goes to sleep.
Control Panel\All Control Panel Items\Power Options\Edit Plan Settings
Regards
Date: 28 Sep 2011 03:59:27
Message: <4e82d3df$1@news.povray.org>
> goes to sleep.
Hey! thanks Stephen! I had not (yet) found that option either! I have
selected High Performance now.
By the way: Personally, I like Windows 7 quite a lot...
Date: 28 Sep 2011 06:05:56
Message: <4e82f184$1@news.povray.org>
An essential setting for all Povers IMO.
So do I. It is a bit resource hungry but my current machine has the
resources. I actually saw the memory usage go higher than 5.5 Gigs today
while I was experimenting with Poser hair.
Regards
Date: 28 Sep 2011 07:18:20
Message: <4e83027c$1@news.povray.org>
Absolutely. I had not looked at the power utility yet because I believed
it was not essential when on a PC. How wrong I was :-)
I should do something to my Windows 7 Curiosity Setting: Very Low; Low;
Average (default); High, Very High.
Mine was set at Low apparently... ;-)
Yes, that can be expected. Best to have enough resources.
Date: 28 Sep 2011 13:35:58
Message: <4e835afe@news.povray.org>
> polished image.
By the way, power management have been there since windows 95 if I
remember corectly... Things like turning display off, powering off the
hard drives when idle, throtling down the CPU if the BIOS support it,...
It's only that some features got added over time as the hardware started
to offer the possibility, and the terminology used seems to have changed
with 7... to some extent.
Date: 29 Sep 2011 15:15:31
Message: <4e84c3d3@news.povray.org>
Windows asks each program if it's OK to go to sleep before it does so.
POV-Ray would have to be coded to recognize that message and deny sleeping
while a render is in progress. Most disk burners, for example, will do this.
   How come I never get only one kudo?
Date: 3 Oct 2011 02:48:14
Message: <4e895aae$1@news.povray.org>
> sleeping while a render is in progress. Most disk burners, for example,
> will do this.
Am I right in assuming that we should put this is the Wish List?
