POV-Ray : Newsgroups : povray.windows : compile povwin-src-3.7 question Server Time
2 Mar 2026 11:50:13 EST (-0500)
  compile povwin-src-3.7 question (Message 1 to 4 of 4)
Subject: compile povwin-src-3.7 question
Date: 23 Nov 2010 03:40:00
Message: <web.4ceb7d5b7e0e98565d1d9d430@news.povray.org>
Hello,
I used visual studio 2005 to compile "povray.sln" in povwin-src-3.7.
I followed ReadMe , but when I executed pvengined.exe in
povwin-src-3.7\windows\vs8\bin32, it show message
This pre-releaseversion of POV-Ray for Windows has expired. We recommend you
obtain a new version,
if one is available,form our website,http://www.povray.org/beta/.
If however you wish to continue using this version,you may do so bu pressing the
EXTEND button,which will re-enable the program for an additional week,at which
time,you will be asked this question again.
If you choose to continue use,please be aware that newer versions that are made
available may fix bugs,add features,or render faster. You are strongly advised
to use newer versions when they become available.
But when I pressed the Extend button,it show another message
"This pre-release version of POV-RAY for Windows expired on 31 Dec 2010."
Can you suggest what should I do,so that I can compile
povwin-src-3.7\windows\vs8\povray.sln?
Additional,in Readme,He says:
"Set 'povwin' as the start-up project if it is not already selected."
But I can't find 'povwin' project.
so what project I should set it a startup projrct.
                                  tltsai
Subject: Re: compile povwin-src-3.7 question
Date: 23 Nov 2010 16:33:14
Message: <4cec331a$1@news.povray.org>
Are you using the most up-to-date sources for beta 39?
An earlier version (38?) had a problem of testing for Juli
2009 but showing Dec 2010 in the message box.
Otherwise: Is your system clock set correctly?
When you open the solution file it should show multiple
projects in the solution explorer.
Date: 23 Nov 2010 23:25:01
Message: <web.4cec9319107126785d1d9d430@news.povray.org>
Does source code for beta 39 release?
I don't see download link on http://www.povray.org/beta/
yes
Date: 24 Nov 2010 19:12:42
Message: <4ceda9fa$1@news.povray.org>
sorry for misleading you, didn't check the latest
available sources. As there was a problem in an earlier
release it is possible the problem is still in the sources
as they are not yet for beta 39. You can circumvent the
problem by adapting the lines
#define EXPIRE_AT       (1272664800 + DAYS(92))
#define HARD_EXPIRY     (1293832800)
in source/backend/povray.h to a later date (in seconds).
It's not supposed to give you a hard expiry until 2011.
I suspect the problem are the lines
   if (_time32 (NULL) > EXPIRE_AT)
     MessageBox (NULL, "This pre-release version of POV-Ray for Windows
expired on 31 Dec 2010.", "Pre-release expired", MB_OK | MB_ICONSTOP) ;
     exit (1) ;
in pvengine.cpp, which look a bit like a copy and paste
leftover from the HARD_EXPIRY test.
