POV-Ray : Newsgroups : povray.windows : error message when installing Server Time
5 Apr 2026 13:29:12 EDT (-0400)
  error message when installing (Message 1 to 4 of 4)
Subject: error message when installing
Date: 1 Aug 2009 00:00:00
Message: <web.4a73bcc0423cb3a81fe11b960@news.povray.org>
I am trying to install povray 64bit for windows XP I get the error message "
This installation is not supported by this processor. Contact your product
vendor."
I get the same message when trying to install it for Vista as well. Anyone know
how to fix this? Or had  a similar problem?
Subject: Re: error message when installing
Date: 1 Aug 2009 01:26:44
Message: <4a73d214$1@news.povray.org>
> vendor."
You do not have a 64 bit Windows installed, so you cannot run 64 bit
applications. You must use the 32 bit version on a 32 bit operating system!
	Thorsten
Date: 1 Aug 2009 10:50:00
Message: <web.4a7455eefba96bb47cb678b90@news.povray.org>
> vendor."
What processor do you have, and exactly what edition of XP and Vista,
respectively?
Date: 1 Aug 2009 22:34:38
Message: <4a74fb3e$1@news.povray.org>
> vendor."
What processor are you using, is it a 64 bits processor?
Are you using Windows XP 64bits edition?
Same question about the Vista version used? They both come in 32 and 64
bits versions.
If you have a 32 bits processor, you need the 32 bits version.
Even if you have a 64 bits processor, if you have a 32 bits OS, you cant
take advantage of the full potential of your CPU as it will be forced to
work in the 32 bits emulation mode.
A 32 bits OS can never run a 64 bits application, ever. There is no
workaround.
Your options:
Use POV-Ray 32 bits.
OR
Install the 64 bits version of your OS.
