POV-Ray : Newsgroups : povray.windows : Passing user-defined parameters Server Time
2 Mar 2026 11:51:58 EST (-0500)
  Passing user-defined parameters (Message 1 to 8 of 8)
Subject: Passing user-defined parameters
Date: 15 Feb 2009 06:40:00
Message: <web.4997fe53b885b11bfb79cd6c0@news.povray.org>
Hello,
I am quite new to povray, but as I read tutorials and any posts regarding
launching povray as a side application there is only one possibility to pass
additional parameters that are required for my images to be rendered.
I want to run povray from my own script and generate number of images that
differs the content. The difference is caused by the parameters used. Is it
only way to do this an additional .inc file with some #declare commands?
It would be much easier to use a command line options...
Any advice appracated.
Best regards,
Twister
Subject: Re: Passing user-defined parameters
Date: 15 Feb 2009 13:38:04
Message: <4998610c@news.povray.org>
Check section 3.1.2 of the manual. Anything there can be put in an .ini file
or can be passed on the command line.  You'll probably want something like
   pvengine.exe myscene.pov +w640 -h480 /render /exit
which sets the size of the scene to render, renders it, then exits.
"pvengine.exe" is the name of the executable in Windows. It's going to bring
up the GUI, but that closes again when it exits after the render.
HTH!
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 15 Feb 2009 14:47:04
Message: <49987138@news.povray.org>
> file or can be passed on the command line.
In particular, see 3.1.2.5.1 "Declare=IDENTIFIER=FLOAT". This can
be  used to set the value of a numeric constant from the command line,
which can then be used a switch in the scene file. Unfortunately, it
does not work for strings (would come in very handy for POV scripts
which actually render text, such as buttons for web pages).
Date: 15 Feb 2009 14:55:01
Message: <web.499871ecd6fa0f35fb79cd6c0@news.povray.org>
Not exactly. I want to generate couple of scenes with different content. As far
as I know there is no other option to do this than specifying this in
additional .inc file. Or I miss something...
I am quite familiar with the tutorial.
Twister
Date: 15 Feb 2009 17:46:21
Message: <49989b3d$1@news.povray.org>
Shamelessly based on the block wall macros in the object library:
#if (frame_number = 0)
#declare my_scene = 5;  // The one you're fiddling with right now
#else
#declare my_scene = frame_number;
#if (my_scene = 1)
#include "MyFirstScene.pov"
#if (my_scene = 2)
#include "MySecondScene.pov"
rem Render scenes 2 though 7 without stopping.
pvengine.exe +KFI2 +KFF7 +IMyMasterScene.pov
Does that help give an idea?
   "Ouch ouch ouch!"
Date: 16 Feb 2009 14:45:35
Message: <4999c25f$1@news.povray.org>
Darren New nous illumina en ce 2009-02-15 13:37 -->
> file or can be passed on the command line.  You'll probably want
> something like
> bring up the GUI, but that closes again when it exits after the render.
> HTH!
If you want to render multiple images in a batch, you can remove the /exit
parameter. Just make sure that tou set POV-Ray to only keep a single instance.
In "Options" check "Keep Single Instance".
So, the command line becomes:
Politicians are like diapers, they should be changed often and for the same reason.
	Bob Monkhouse
Date: 16 Feb 2009 14:46:35
Message: <4999c29b@news.povray.org>
twister nous illumina en ce 2009-02-15 14:50 -->
> Regards,
> Twister
'Power corrupts. Absolute power is kind of neat, though.'
Date: 16 Feb 2009 14:49:12
Message: <4999c338$1@news.povray.org>
> Regards,
> Twister
This will render 4 scenes from 4 sources files then exit after the last one is
finished:
pvengine.exe myscene1.pov +w800 +h480 /render
pvengine.exe myscene2.pov +w640 +h480 /render
pvengine.exe myscene3.pov +w480 +h700 /render
pvengine.exe myscene4.pov +w1024 +h768 /render /exit
You know you've been raytracing too long when you even think about using Povray
for writing letters.
Sven Rudolph (Germany)
