POV-Ray : Newsgroups : povray.windows : A question about save the result! Server Time
2 Mar 2026 13:43:25 EST (-0500)
  A question about save the result! (Message 1 to 4 of 4)
Subject: A question about save the result!
Date: 6 Apr 2008 10:40:00
Message: <web.47f8e03b8f3385c035072ccd0@news.povray.org>
i am a new bird to use pov-ray for windows,meet a problem about save the
result.
   i want to save images that are created by the same scene below different
camera.but i just find the last image,not all.
   how can i get all the image? how to write command in the POV-ray for windows?
   thank you for your attention!
Subject: Re: A question about save the result!
Date: 6 Apr 2008 11:52:31
Message: <47f8f1bf$1@news.povray.org>
andy Wang napsal(a):
> result.
The image has the same name as the file that is used to create it, unless:
-you use the animation feature by setting the final_frame in the command
line and then using frame_number in the scene to decide which camera to
display. In this case the files are numbered by the frame number.
Example:
#if(frame_number==n)
  camera{
-you set output_file in the command line, which overrides the automatic
naming completely. In this case you select the camera to be rendered
manually.
-the newest beta has a real-time camera animating feature that renders
all the cameras one after another. However, I don't know whether this
feature saves any of these images.
Unless you use the last option specified (I assume you use v3.6 - which
you should) Povray always renders the last camera added to the scene.
the command line options are typed in the text box next to where you
select the output resolution (second from the left).
You know you've been raytracing too long when...
you ever saw a beautiful scenery and regretted not to take your 6"
reflective ball and a digital camera, thinking "this would have been a
perfect light probe"
-Johnny D
Date: 6 Apr 2008 14:59:18
Message: <47f91d86@news.povray.org>
Images rendered by realtime mode aren't saved to disk.
Date: 6 Apr 2008 15:00:27
Message: <47f91dcb@news.povray.org>
andy Wang nous apporta ses lumieres en ce 2008/04/06 10:37:
> result.
You can use the animation feature and a #switch(frame_number) structure or to
use the clock variable to make the camera travel, to generate a serie of
distinct images.
Another, manual, solution is to go and rename the just rendered image before
rendering with the different camera.
The manual way is good for a few images.
The #switch is goos for retively few images where the various cameras are all
distinct.
The use of clock is good if you want many positions along a path. The use if #if
or #switch can be added if you want more than one trajectory.
Remember that, by default, clock goes from 0 to 1.
Cat, n.: Lapwarmer with built-in buzzer.
