POV-Ray : Newsgroups : povray.windows : read problem in Win Vista Server Time
2 Mar 2026 13:42:58 EST (-0500)
  read problem in Win Vista (Message 1 to 4 of 4)
Subject: read problem in Win Vista
Date: 15 Feb 2008 21:50:00
Message: <web.47b64f0d36bc6f2192254edf0@news.povray.org>
I have been trying to read from a file containing rotation vectors for joints
involved in a move, however I could not get it working.
I set up a while loop to read all the records in the file,  in the while
loop, POV-RAY reads the first record correctly, however in the second record it
complains about "Expecting a float, string, or a rotation vector, but finding a
instead."
I could not see anything different between 1st record it likes and the 2nd it
bumbs on, I even copied the 1st record twice to see if it will read it for the
seond time, it had not.
Again, here is my walk01.txt file:
"L_Hip_Ind",3,<-40,0,0>
"L_Knee_Ind",4,<0,0,0>
"L_Ankle_Ind",5,<50,0,0>
"R_Hip_Ind",13,<45, 0, 0>
"R_Knee_Ind",14,<5, 0, 0>
"L_Elbow_Ind",10,<2, 0, 0>
"R_Acromioclav_Ind",18,<0, 10, 0>
"L_Acromioclav_Ind",8,<0, -10, 0>
"R_Acromioclav_Ind",18,<-40, 0, 20>
"R_Elbow_Ind",20,<-90, 0, 0>
"R_Ball_Ind",17,<-60, 0, 0>
"Lower_Back_Ind",2,<-0,0,0>
"HumanoidRoot_Ind",0,<20, 0, 0>
Here is the loop that POV-RAY refuses to  use to read beyond 1st record:
         #fopen PosFile "walk01.txt" read
         #while (defined( PosFile ))
            #read (PosFile, Joint_Name, AVar_Ndx, Rot_Vector )
            #declare AVAR[1][AVar_Ndx] = Rot_Vector * clock;
            #debug concat( Joint_Name, ",", str(AVar_Ndx, 2, 0), ",",
                           vstr( 3, Rot_Vector, ", ", 3, 0), "\n" )
         #fclose PosFile
Any insight would be greatly appreciated, I attempted embedding blank spaces
among the three elements I am trying to read off of the file.  No matter what
combinations I had tried, I could not succeed.  I looked at the file with a hex
code encoder to make sure no funny invisible character was hiding.  Nope it was
not.  Carriage Return character was at the end of each line right after ">"
closing bracet of the Rot_Vector.
Thanks,
Meltem
Subject: Re: read problem in Win Vista
Date: 16 Feb 2008 00:32:47
Message: <5Gh1T8I3VntHFwY5@econym.demon.co.uk>
>instead."
POVRay doesn't see line breaks as being field separators. You need to
have commas at the end of each line except the last.
Mike Williams
Gentleman of Leisure
Date: 16 Feb 2008 20:14:30
Message: <47b78a76@news.povray.org>
Mike Williams nous apporta ses lumieres en ce 2008/02/16 00:32:
>> joints
>> record it
>> finding a
>> instead."
>> 2nd it
>> for the
You can even have an extra, and useless, coma after the last item.
The tree of liberty must be refreshed from time to time with the blood of
patriots and tyrants.
Thomas Jefferson
Date: 21 Feb 2008 01:50:00
Message: <web.47bd1e75cc21e5dd587ef5e20@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
Thank you gentlemen, adding commas surely did the trick.  It was one of those
things that had never occurred to me, neither had I noticed it mentioned in the
online documentation.
> >> joints
> >> record it
> >> finding a
> >> instead."
> >> 2nd it
> >> for the
> Alain
> Thomas Jefferson
