POV-Ray : Newsgroups : povray.windows : Exporting images Server Time
16 Mar 2026 22:37:46 EDT (-0400)
  Exporting images (Message 1 to 5 of 5)
Subject: Exporting images
Date: 22 Jun 2005 10:20:01
Message: <web.42b971ecc9320edde5987fa60@news.povray.org>
I'm using PovRay for windows, and i can't figure out how to make the output
file anything but the default 24-bit BMP? I'd like to export to a PGM or
other lossless format with 16bits per colour.
Thanks,
Ryan
Subject: Re: Exporting images
Date: 22 Jun 2005 10:32:42
Message: <42b9768a@news.povray.org>
Ryan wrote:
> Hi,
> Thanks,
> Ryan
Um, Read the help, specifically the part on command line options:
http://www.povray.org/documentation/view/3.6.1/219/
Also, PNG, TGA, PPM and SYS (BMP in the case of Windows) are the only
formats available, for anything else you'll have to use a conversion
program, of which there aer plenty available.
~Mike
Things! Billions of them!
Date: 22 Jun 2005 10:50:00
Message: <web.42b979852f69a761e5987fa60@news.povray.org>
Thanks, i've already looked at that, but it's for the command line version -
not the Win GUI. How do I input command line options in the Win version? I
have tried inputting the commands at the top of the .pov file but this
returns errors not recognising them!
Thanks - i'm very new to POV!
Mike Raiford <mra### [at] hotmailcom> wrote:
> Ryan wrote:
> > Hi,
> > Thanks,
> > Ryan
> ~Mike
Date: 22 Jun 2005 11:25:00
Message: <web.42b981c62f69a761ccf67d800@news.povray.org>
> > Ryan wrote:
> > > Hi,
> > > Thanks,
> > > Ryan
> > ~Mike
Try using an ini file. You can set anything you need there.
Date: 22 Jun 2005 11:29:03
Message: <42b983bf$1@news.povray.org>
>>Ryan wrote:
>>>Hi,
>>>Thanks,
>>>Ryan
>>~Mike
As m1j replied, the INI file, or just to the right of the resolution
pull-down, you'll notice an empty box, here you can enter command-line
options.
~Mike
