POV-Ray : Newsgroups : povray.windows : render output size Server Time
2 Mar 2026 17:21:34 EST (-0500)
  render output size (Message 1 to 4 of 4)
Subject: render output size
Date: 31 Jan 2005 12:25:00
Message: <web.41fe6991dc7f689943383c9d0@news.povray.org>
i'm noobie here.
i'm a wings3d user, and i'm becoming a povray user because Kayosiii
has atualized his plugin to render/export from wings to pov.
i would like to know how can i specify the output size of the rendered
image?
Or i only have the size options under render|render settings???
(i am working at 3.5 release).
thanks in advance.
Subject: Re: render output size
Date: 31 Jan 2005 17:39:16
Message: <41feb394$1@news.povray.org>
Fonte Boa nous apporta ses lumieres en ce 2005-01-31 12:23:
> i'm noobie here.
> image?
> thanks in advance.
In the windows version, there is a "command line" box. in it, you can enter something
like +w400
+h1200 to get a 400 by 1200 pixels image.
Date: 31 Jan 2005 18:45:01
Message: <web.41fec2dd3b05743aa9ff29800@news.povray.org>
Thank you, Darren: i'll try edit quickres.ini to create another resolutions
in that list.
Thank you, Alain: i'll experiment povray by the command line.
great community here!
Date: 1 Feb 2005 06:56:19
Message: <41ff6e63@news.povray.org>
  There's no need to run POV-Ray for Windows from the command line.
  There's a textfield on top of the window which is called "command-line"
because it accepts the same options as command-line versions of the
program. You just have to write the +w and +h options in that textfield.
