POV-Ray : Newsgroups : povray.windows : Program Suggestion (comments) Server Time
2 Mar 2026 17:22:11 EST (-0500)
  Program Suggestion (comments) (Message 1 to 7 of 7)
Subject: Program Suggestion (comments)
Date: 6 Nov 2004 10:45:00
Message: <web.418cf108ec92fcd97d1f61010@news.povray.org>
If you have to comment/uncomment a large block of code, it can be tedious to
keep entering "//" all the time. It would be nice if comment/uncomment
options were available on the Right-Click/Text menus, much in the same way
that indent/undent are available.  I already know about '/*...*/', but this
would be be more selective, and easier to understand for newer users.
Also, this could be implemented on other platforms as well.
Subject: Re: Program Suggestion (comments)
Date: 6 Nov 2004 12:36:22
Message: <Xns9599BD44A4106seed7@news.povray.org>
> tedious to keep entering "//" all the time.
Are you aware of the possiblity to use CTRL+click and drag to select a
block. Select a minimal 'width-block' just in front of the text, then type
'//'. It's not exactly what you ask but it works fine.
Ingo
Date: 6 Nov 2004 15:57:37
Message: <418d3ac1@news.povray.org>
  Sorry, could you profundize on this? I don't understand why.
Date: 8 Nov 2004 08:05:01
Message: <web.418f6e79550724c549700cac0@news.povray.org>
As a matter of fact, I was just about to log in here and request a feature
like this. Perhaps a little note about this very helpful feature could be
included in the documentation at the next release (I don't believe it is
included at the moment)?
-Mike
Knights Of Today
Date: 8 Nov 2004 10:13:02
Message: <Xns959BA4F7F284Cseed7@news.povray.org>
1.2.6.1  The Editor Feature Set
 - Column Selection and Manipulation
and
1.2.6.6.5  Using the Mouse
Ingo
Date: 8 Nov 2004 16:28:21
Message: <418fe4f5@news.povray.org>
> and
Ah, must have missed those. Thanks. :)
Date: 13 Nov 2004 15:10:00
Message: <web.41966957550724c57d1f61010@news.povray.org>
Thanks. I didn't know about the block selection trick. But It would still be
useful to have it as a right-click option; after all if you can
indent/undent, change the case, and convert between tabs and spaces, why
not comment/uncomment too?
