POV-Ray : Newsgroups : povray.windows : Povray without installation? Povray in a grid. Server Time
14 Dec 2025 17:00:27 EST (-0500)
  Povray without installation? Povray in a grid. (Message 1 to 5 of 5)
Subject: Povray without installation? Povray in a grid.
Date: 8 Oct 2004 10:20:00
Message: <web.4166a1cdfbcfaaae1bc421ef0@news.povray.org>
Hello!
I need a standalone povray version for Windows without an installer (and
registry entries). All what i need is just the renderer, no GUI etc. Is
there something like that available?
I need that for following purpose:
We set up a High Throughput Computing pool with lots of machines in it. Now
i can submit the server lots of Jobs (An executable with commands,
additional files etc.) and the server looks for machines in that pool that
match best the requirements of the job and let that machine execute and
send back the results.
So.. Povray on Linux-machines works properly with that, i send a big
renderjob (movie) and the server gives pieces of that job to linux-machines
which execute that job. The server has to send the povray-executable and
the ini-file(s) to each execute machine - works fine, especially you have
big renderjobs.
The problem is povray on Windows machines. I haven't found any solution, how
i can render something with povray without having installed povray (3.6).
The registry entries seem to be important. But I mustn't just add these
registry entries on the execute machines.
Is there a povray version that can work without beeing installed. Only the
renering is required, the GUI etc. should not been started. Just start -
render - exit, without installation.
Thanks for help
Thomas Lisson
Subject: Re: Povray without installation? Povray in a grid.
Date: 8 Oct 2004 10:55:02
Message: <ck69hd$mkv$1@chho.imagico.de>
Crysus wrote:
> Hello!
> big renderjobs.
You can build the Unix version of POV-Ray on Windows without problems.
But POV-Ray for Unix also requires an installation to function properly.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 8 Oct 2004 10:55:26
Message: <4166aa5e$1@news.povray.org>
Quick solution:
Install MINGW, which will give you a linux shell under windows.
./configure
make
and TADA - you have a statically compiled POVRAY.EXE somewhere in your disk.
Insteresting that I did just exactly what you want.  I made the whole
fractal.pov video (+1000 frames) using Condor.
Henrique Bucher
"Crysus" <nomail@nomail> wrote in message
news:web.4166a1cdfbcfaaae1bc421ef0@news.povray.org...
> Hello!
> Now
> linux-machines
> big renderjobs.
> how
> Thanks for help
> Thomas Lisson
Date: 14 Oct 2004 09:15:01
Message: <web.416e7b8721a064341bc421ef0@news.povray.org>
Hi!
Thank you very much for your solutions. It works great.
I also use the Condor environment.
greetz
Thomas Lisson
Date: 4 May 2007 09:30:02
Message: <web.463b30ff21a064345fb7d6ee0@news.povray.org>
"Henrique" <hen### [at] hotmailcom> wrote:
> Quick solution:
> ./configure
> make
> Henrique Bucher
> > Hello!
> > Now
> > linux-machines
> > big renderjobs.
> > how
> > Thanks for help
> > Thomas Lisson
and it borrows a lot from the EGEE European GRID.
EELA:
www.eu-eela.org
EGEE:
www.eu-egee.org/
Do you have any advice on how to run POVRAY on a grid system both for
animations and still renders(sectioning the scene)?
So far I have found an old mpi version of povray 3.5c right on these forums
but nothin related to the latest version.
Thank You in advance.
