POV-Ray : Newsgroups : povray.windows : Compile a 64-bit version of Povray on Windows Server Time
15 Dec 2025 17:00:47 EST (-0500)
  Compile a 64-bit version of Povray on Windows (Message 1 to 7 of 7)
Subject: Compile a 64-bit version of Povray on Windows
Date: 16 Dec 2003 16:30:02
Message: <web.3fdf791e576c20ec53e0ca340@news.povray.org>
I downloaded the Povray source code and compiled a 64-bit version of it for
WindowXP-64bit.  When I tested it against the 64-bit machine, it complained
that there were registry entries missing.  So I installed Povray as what I
did for a 32-bit windows.  The installation went O.K.  But obviously the
components installed donot match what's needed by a 64-bit Povray exe.  It
crashed.
Do they have a 64-bit version installation?  I could not find anything on
the web.  Can anyone help me to make it work?  I used Intel 64-bit compiler
versin 8.0.
Thanks!
Subject: Re: Compile a 64-bit version of Povray on Windows
Date: 16 Dec 2003 18:58:21
Message: <Xns9453C0E6F3A4Ctomatimporg@204.213.191.226>
"Judy Hopkins" <jho### [at] seismicmicrocom> wrote in
news:web.3fdf791e576c20ec53e0ca340@news.povray.org:
> it for WindowXP-64bit.
This might be better asked in povray.programming.  Also, I am curious to
why you want to do this?  AFAIK, you would not be gaining much with a 64
bit compile, without making major changes to the source code.
Tom
_________________________________
The Internet Movie Project
http://www.imp.org/
Date: 16 Dec 2003 19:30:02
Message: <web.3fdfa2af581a6a8753e0ca340@news.povray.org>
I am preparing for an intro presentation on 64-bit programming.  Povray can
be used to demo the use of a few compiler performance switches such as IPO
and PGO.
Is povray.programming another newsgroup?  I will look for it.
Date: 16 Dec 2003 20:10:38
Message: <3fdfad0e@news.povray.org>
  He would if he had more than 4 gigabytes of memory. I find it quite
unlikely, though. :)
Date: 16 Dec 2003 22:46:53
Message: <Xns9453E7A6A9FDBtomatimporg@204.213.191.226>
news:web.3fdfa2af581a6a8753e0ca340@news.povray.org:
I see you found it ;)
Tom
http://www.imp.org/
Date: 16 Dec 2003 22:47:47
Message: <Xns9453E7CD8DEABtomatimporg@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3fdfad0e@news.povray.org:
You mean "she" would ;)
Tom
http://www.imp.org/
Date: 17 Dec 2003 09:15:02
Message: <web.3fe064db581a6a874e87b9c0@news.povray.org>
I have access to several machines with more than 4 gig or memory (I think
the biggest one has 8) and I certainly would like to try a nice big scene
with high quality radiosity settings just to see whether it would work.
