POV-Ray : Newsgroups : povray.windows : Help, I'm having severe editor problems Server Time
1 Apr 2026 11:29:31 EDT (-0400)
  Help, I'm having severe editor problems (Message 1 to 6 of 6)
Subject: Help, I'm having severe editor problems
Date: 5 Oct 1999 03:47:33
Message: <nKn5N3YJ7GNtrSpdR8MrucwQdWba@4ax.com>
When I try to open any file with POV-Ray for Windows V3.1g, I get
error messages such as these:
POV-Ray Editor - Division by zero
POV-Ray Editor - Access violation at address 012A01FC in module
'CMAX101.DLL'. Read of address FFFFFFFF.
POV-Ray Editor - Access violation at address 012A1670 in module
File 'torus1.pov' - Failed to open file: The operation completed
successfully.
Whatever is causing this also affects the Super Patch and the Mini
Patch as well. I have tried uninstalling and reinstalling. I also
tried manually removing every mention of POV from the registry and
win.ini before one of the reinstallations. After several attempts, I
still can't get the problem corrected. Any help is most appreciated.
Thanks,
Glen Berry
To reply via email, remove the "7" from nos### [at] ezwvcom
Subject: Re: Help, I'm having severe editor problems
Date: 5 Oct 1999 04:08:37
Message: <37f9b205@news.povray.org>
First of all: Is your computer overclocked?
Date: 5 Oct 1999 04:24:46
Message: <M7X5N+gClvjn=GLVbmTxT5eY6yKv@4ax.com>
No, just a normal Pentium 133.
My other software seems to work okay, but recently POV quite working.
I don't know if perhaps I installed something that screwed up a
windows dll or perhaps one of the recent power failures messed up
something, I just don't know what is causing this.
Date: 5 Oct 1999 04:29:51
Message: <37F9B6F5.EE0FC42C@pacbell.net>
I was plagued by this problem with POV-Win 3.1d but with POV-Win 3.1g
a new editor .dll file was introduced that was supposed to fix this
problem. This is the first report I have seen with this error since
the revised edition came out. Are you sure you are using the right
version of codemax cmax101.dll ?
Got bad ram at that address ?
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 5 Oct 1999 07:11:47
Message: <uNv5NzLQYX6jFrvUnJPC2I6AnHf2@4ax.com>
It's the one that came with POV 3.1g, so it should be the proper one.
I did a search of my entire system for any other copies and couldn't
find any.
I hope not, but I'm not sure how to rule that out. Like I said, my
other software seems to be working okay, so I'm hoping that it isn't
something like bad RAM.
For what it's worth, I *can* render files with POV, but I can't open
them in the internal editor. It's a bit awkward after being used to
using the internal editor.
Date: 5 Oct 1999 09:15:49
Message: <37f9fa05@news.povray.org>
Not likely.  It's not an address that would normally be used for anything.
It's being accessed because there's a bad pointer somewhere.  In any case,
virtual memory means never being able to relate an address to a physical
piece of memory, so even if it was bad RAM it wouldn't always map to the
same address.
