POV-Ray : Newsgroups : povray.windows : Greetings from Vienna (Austria) Server Time
2 Apr 2026 00:30:32 EDT (-0400)
  Greetings from Vienna (Austria) (Message 1 to 2 of 2)
Subject: Greetings from Vienna (Austria)
Date: 4 Apr 1998 12:00:34
Message: <6g5okh$6du$1@oz.aussie.org>
Hello!
I am currently writing my dissertation at the University of Vienna
(Psychological Institute) in Austria (Europe) and I have the problem to
develop items (for an adaptive computertest of spatial abilities) such as
the one attached to this email.
My question: Is it possible to create test-items like the one attached to
this email with the software "Povray"?
Thank you,
Martin
Martin E. Arendasy, MSc, PhD-Candidate
Vienna, Austria
Tel, FAX: (+43 1) 2789727
Email:    mel### [at] netwayat
Download 'EST.jpg' (23 KB)
Preview of image 'EST.jpg'
Subject: Re: Greetings from Vienna (Austria)
Date: 4 Apr 1998 16:24:54
Message: <3526A523.BC6C0452@dhol.com>
Martin E. Arendasy wrote:
> Hello!
> to
> as
> to
It is not difficult at all to do this with POV.  There are many ways,
but I like to use blob cylinders along splines.  You get a nice smooth
result this way with fewer pieces needed.  Here is a quick demo I did
for someone else.  Get Chris Colefax's spline include file at
http://www.geocities.com/SiliconValley/Lakes/1434 and use it with this
file.  The documentation for the spline include (along with the comments
in this demo) should get you going. Email if you need more information.
Here are Spldem.pov and Spldem.spl:
//Begin POV-Ray file Spldem.pov
// Blob Spline demo - a bent wire
#include "textures.inc"
#include "metals.inc"
camera
  location <5,10,-12>
  look_at  <4,5,0>
light_source
  <0,20,-40>
  color rgb 1
#declare Size = 1000 // How many pieces in the spline; more = smoother
but slower
#declare Radius = .25 // Adjusts thickness of wire
#declare Acc = 1/Size // How far apart spline points are
#declare spline_clock  = 0 // Spline.inc uses this
 blob { threshold .6 // The whole wire is one big blob object
  #while ( spline_clock < 1 )
  #include "Spldem.spl" // Use Spline.inc to generate points
   #if ( spline_clock >= Acc )
      #declare P = spline_pos // get this cylinder ending point
   #if ( spline_clock = Acc )
    #declare OldP = P - .00001 // Get first cylinder starting point
   cylinder { OldP, P, Radius, 1
    texture { T_Gold_3C } } // Blob component
      #declare OldP = P // Get next cylinder starting point
    #declare spline_clock = spline_clock + Acc
// End Spldem.pov
// Begin spline points file Spldem.spl
#declare spline_segments = 5 // how many segments
#declare spline_loop = false // make this true to close the spline
// It can help to pick points halfway between the sharp bends instead of
at them
#declare point0 = <0,0,0>
#declare point1 = <1,2,4>
#declare point2 = <3,5,4>
#declare point3 = <2,4,7>
#include "Spline.inc"
#declare point2 = <5,1,3>
#declare point3 = <7,6,9>
#declare point2 = <3,8,5>
#declare point3 = <6,2,4>
#declare point2 = <9,0,5>
#declare point3 = <7,4,3>
#declare point2 = <5,3,7>
#declare point3 = <10,10,10>
// if you want to close the spline smoothly, adding a segment with
// point2 and point3 = point0 and point1 helps
// End Spldem.spl
Jerry Anning
cle### [at] dholcom
