POV-Ray : Newsgroups : povray.windows : shell to povray Server Time
16 May 2026 03:30:01 EDT (-0400)
  shell to povray (Message 1 to 6 of 6)
Subject: shell to povray
Date: 24 Mar 1998 18:31:40
Message: <6f9fkq$7np$1@oz.aussie.org>
I'm writing an app that will run povray with command line switches etc....
Is there a way to determine how far along a render is, or a way to get feed
back from the output of POVRay for windows??
Mike
Subject: Re: shell to povray
Date: 25 Mar 1998 08:06:37
Message: <6favgt$bot$1@melchior.cuivre.fr.eu.org>
For Windows, I am not sure. Try redirecting the output and error streams
to files, then parse these files (with Perl for instance), or try with pipes.
For DOS, the probability of this being possible is increased. For Linux,
it becomes 100 %. For other systems, I do not know. Anyway, you can still use
the DOS command-line version of POV (which even renders faster than the Windows
one), and parse the output files.
Happy ray-tracing,
Roland.
bob### [at] casimirrezelenstfr -- Linux, POV-Ray, LaTeX
Date: 25 Mar 1998 10:50:34
Message: <351927a7.6908463@news.stmuc.com>
If you use the DOS/Unix versions, you can pipe the actual pixels to a program.
Date: 25 Mar 1998 10:14:25
Message: <6fb6s6$amg$1@oz.aussie.org>
Since the application is in Windows, I'll be using POVRay for windows.  The
output of POVRay can be redirected to a file, but the statistics appears
only after the rendering is complete.  I noticed that Lutz wrote a DLL to
improve the communciations between POVRAY and MORAY.  hmmmm  I wonder if
there's a way to tap into that???
povray.org admin team wrote in message <351### [at] newsstmuccom>...
pipes.
use
Windows
program.
Date: 25 Mar 1998 15:25:29
Message: <351d67fa.26879861@10.0.2.33>
On Wed, 25 Mar 1998 07:14:25 -0800, "Mike Weber"
Go check out the windows/guiext subdirectory in your POV source
directory.  I'd tell you to go over to povray.windows.gui-extensions,
but it seems to have been a casualty of the recent changeover.  There
wasn't much traffic there, anyway.
Date: 25 Mar 1998 20:07:26
Message: <3519aa3e.4112313@news.stmuc.com>
It's been replaced by povray.programming.
-- Admin
