POV-Ray : Newsgroups : povray.windows : Question about camera multi-view Server Time
31 May 2026 13:14:43 EDT (-0400)
  Question about camera multi-view (Message 1 to 5 of 5)
Subject: Question about camera multi-view
Date: 13 May 2010 12:47:50
Message: <4bec2d36$1@news.povray.org>
Hi all,
A long time haven't used POVray, but want to return :-)
I just wonder if such a 'tools' would exit, to render for a single scene
multiple views as if 3 (for example) cameras was in the scene ?
Purpose would be to get eg 3 rendered images with different point of
view without changing the camera attribute in the source scene...
Any idea for that ??
Thanks,
ALeX
Subject: Re: Question about camera multi-view
Date: 13 May 2010 13:24:59
Message: <4bec35eb$1@news.povray.org>
Am 13.05.2010 18:47, schrieb Alex:
You /will/ have to set up multiple different cameras in the scene, using
some #if construct to choose between them (driven either by animation
variables or ini Declare=... statements).
Or you might use ini Declare=... to set parameters that you'll then use
in the camera statement.
Date: 13 May 2010 13:31:39
Message: <4bec377b$1@news.povray.org>
Hi again ;-)
That I already do, but my request is to press the "Run" button only once
and to get multiple angles views of my scene to check is from different
cameras view...
Thanks
Date: 13 May 2010 14:18:55
Message: <4bec428f$1@news.povray.org>
Am 13.05.2010 19:31, schrieb Alex:
> Hi again ;-)
> cameras view...
You can do that using the animation mechanism - using as many frames as
you have camera views.
Date: 15 May 2010 05:29:29
Message: <4bee6979$1@news.povray.org>
> Hi all,
> Thanks,
> ALeX
Just for interested people, that thread is closed (at least solved) in
povray.newusers.
Cheers !
