POV-Ray : Newsgroups : povray.windows : recursive comments Server Time
31 May 2026 18:01:13 EDT (-0400)
  recursive comments (Message 1 to 5 of 5)
Subject: recursive comments
Date: 27 Jun 2004 07:38:21
Message: <40deb1ad@news.povray.org>
I've found that comment-pairs /* and */ can not be applied recursively in the
editor.
When the scene is rendered there is no problem. commented bloCks  are handled
correctly by the compiler/renderer.
Bug or feature?
I'm using Windows XP with POV-ray v3.6.0.icl8.win32
Maurice
Subject: Re: recursive comments
Date: 27 Jun 2004 09:35:54
Message: <40decd3a@news.povray.org>
SomeOne <ask### [at] yahoocouknospam> wrote:
> Bug or feature?
  A deficiency in the text editor, which is not developed by the pov-team.
Date: 27 Jun 2004 20:36:53
Message: <40df6825@news.povray.org>
I also noticed that. It's good that you can nest comments in that way although
the editor color-codes them incorrectly.
- Nicolas Alvarez
nicoalvar0 [at] hotmail [dot] com
news:40deb1ad@news.povray.org...
> editor.
> Bug or feature?
> Maurice
Date: 29 Jun 2004 06:35:30
Message: <40e145f2$1@news.povray.org>
This is a bug in the editor -- with usable side-effects:
These
lines
are
a
comment
But
not
these
lines
I.e. adding/removing a single slash can switch off/on
a large block of code (a nice trick published some
time ago on one of these newsgroups; dont't know
anymore by whom).
A two-level nesting of comments is possible by
using both types of comments; this works:
comment
// comment
comment
// comment
// /* comment
// comment
// comment */
// comment
Prefixing many lines by "//" is easy in the windows
version: click on the beginning of the first line to
become a comment, then shift-alt-click on the
beginning of the last line to become a comment.
This gives a long vertical cursor. Then type "//"
(without the apostrophes) -- that's all.
Or get this long vertical cursor by alt-dragging
from the beginning of the first to the last line.
And of course "//"-comments can be nested
without limitation:
// comment
// comment // comment
// // comment
//// comment
// comment
   Sputnik
Date: 29 Jun 2004 14:24:06
Message: <40e1b3c6@news.povray.org>
  No, it isn't.
  A bug is a programming mistake: The programmer wanted to achieve some
effect, but he made a programming mistake and the code doesn't work.
  This is clearly not a bug: It works exactly as the programmer wanted
it to work. It's just that the programmer didn't expect that some
language would use nested /* */ comments and didn't make any code
to handle that.
  It's just a deficiency, not a bug.
