POV-Ray : Newsgroups : povray.windows : changing center & batch Server Time
17 Mar 2026 02:45:40 EDT (-0400)
  changing center & batch (Message 1 to 6 of 6)
Subject: changing center & batch
Date: 12 Mar 2003 11:34:28
Message: <3e6f6194@news.povray.org>
1-can I change the center(pivot) of an object?
2-can I render multiples pov files with a .bat file?
thanks!
Luciano
Subject: Re: changing center & batch
Date: 12 Mar 2003 11:56:57
Message: <jhpu6vc431c1i2loqn973svkv0i7nqiv8t@4ax.com>
There is nothing like center of object. There is center of coordinate
system. You can translate your object to move cewnter of coordinate system
relative to your object in your favourite way.
Look for 'queue' keyword on toolbar, menu and documentation.
ABX
Date: 12 Mar 2003 12:37:47
Message: <3e6f706b$1@news.povray.org>
Presumably you mean the centre for rotations?  If so, it's worth
pointing out that all rotations are performed around <0,0,0>.  So, if
you want to rotate around the corner of a cube (for example), simply
make sure that the cube's corner is at <0,0,0> before applying the
rotation.
However, if you look into the "transforms.inc" file and its contents,
you'll find some useful macros such as Rotate_Around_Trans, which will
rotate an object around whatever point you specify.
Date: 12 Mar 2003 13:48:35
Message: <3e6f8103$1@news.povray.org>
thanks Andrew and ABX for your help!
obrigado por escrever!
Prefeitura de Rock-Ville
ROCK-VILLE
http://www.rock-ville.com
"Andrew" <ast### [at] hotmailcom> wrote in message
news:3e6f706b$1@news.povray.org...
> rotation.
Date: 14 Mar 2003 10:53:39
Message: <3e71fb03$1@news.povray.org>
"bona" <bon### [at] tramacombr> wrote in message news:3e6f6194@news.povray.org...
> Hi,
A common misconception - I'm fairly sure this one is in Warp's VFAQ. Easy to see
where it comes from, and one can often get away with believing this
misconception for quite some time, despite extensive use of POV (well, I did at
any rate, but then I'm a known idiot).
If you haven't found Warp's VFAQ yet, go to:
http://www.students.tut.fi/~warp/
or, more specifically:
http://www.students.tut.fi/~warp/povQandT/languageQandT.html#rotating
Date: 14 Mar 2003 10:54:39
Message: <3e71fb3f$1@news.povray.org>
BTW no biggie, but this message might have been better posted to newusers...
