POV-Ray : Newsgroups : povray.windows : info: command line inability to process spaces in pathname Server Time
17 Mar 2026 02:44:43 EDT (-0400)
  info: command line inability to process spaces in pathname (Message 1 to 3 of 3)
Subject: info: command line inability to process spaces in pathname
Date: 17 Jan 2003 19:36:15
Message: <3e28a17f@news.povray.org>
This message is shown when using +O"c:\image files\test.png" in the P.-R.
for W. (XP) command line field. Just to check other ways I put quotes around
only the 'image files' part too with same result.
Possible Command Line Error:  File name or path parameter expected for
switch 'o', found 'c:\image'.
Command Line Error: Problem with command line or INI file.
Thorsten explains this as something which POV-Ray was not designed to be
capable of, and I'm posting this here per his request at povray.general.
Thread is:
<3e26e82f@news.povray.org>
or
http://news.povray.org/povray.general/29860/
In the Windows Help, section 5.2.2.3.2 Output File Name it does not warn
against the use of spaces in paths and file names. Could be a very good idea
to appended a note there saying as much. Possibly also at section 1.10.7.1.1
Edit Settings/Render and/or 1.7.1.3 Toolbar Command Line.
Another place which could benefit from a note is 5.1.1 Command Line
Switches. And when I was reading that part over I noticed it still claims
only 10 library paths are possible, not 20. I don't remember that needing to
be different from the INI limit.
Possibly some things for ingo to look into for making a change. This is like
deja vu to me because I thought all this was covered long ago. Could be I'm
not recalling the final position taken on these two things.
Farewell,
Subject: Re: info: command line inability to process spaces in pathname
Date: 18 Jan 2003 04:55:04
Message: <3e292478$1@news.povray.org>
In article <3e28a17f@news.povray.org> , "hughes, b." <omn### [at] charternet>
> Thread is:
> or
No, you misunderstood: I said that without quotes it is not officially
support and simply cannot work on the commandline because it is just not
possible no matter how it is designed.  The only problem here is that quotes
(according to you, I did not verify this) do not work when used in the
Windows commandline field.  And for this and no other reason I suggested to
post here.
    Thorsten
e-mail: tho### [at] trfde
Date: 18 Jan 2003 11:07:14
Message: <3e297bb2@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e292478$1@news.povray.org...
> > Thread is:
> > or
quotes
to
> post here.
I see, sorry about that. Double-checked, and yes, quoting the path in the
command line causes the error mentioned before. Which once again is:
when +o"c:\image files\test.png" is used.
WinXP
Thanks for clarifying what might be a problem (ignored "") versus the way it
is by design. Seeing as how I could find nothing documented in the Scene or
Windows Help about any of this it could cause some confusion.
Bob Hughes
