POV-Ray : Newsgroups : povray.windows : C/C++ question. Server Time
5 Sep 2025 11:19:57 EDT (-0400)
  C/C++ question. (Message 1 to 3 of 3)
Subject: C/C++ question.
Date: 4 Oct 2002 18:16:01
Message: <3d9e1321@news.povray.org>
Ok, I've only got one last thing to add to this silly GUI Extension, and I
just can't figure out how to do it.  It's a simple simple thing to do, I
just haven't worked in C/C++ so long, and I don't have any C++ books
anymore.
From the command-line the user passes in a file let's say "scene.pov".  Now,
POV wants the GUI Extension to pass the full path name of the file, let's
say, "c:\povfiles\scene.pov".
Here are my questions.  How can I tell if a file exists?  How can I get the
"current working directory" in a C program? in a C++ program?  How can I
tell if a file path is absolute?  This will only ever run on Windows, so
Windows API calls are ok too...
Thanks!
#macro Q(A,E,W)box{-A/2,A/2pigment{rgb 9*W}translate E*A+W/1000}#end#macro
M(D,E)#local A=1/pow(3,D);#if(D<3)#local C=D+1;union{M(C,1)M(C,x+y)M(C,x+z)
M(C,y+z)M(C,x+y-z)M(C,x+z-y)M(C,y+z-x)M(C,x-y)M(C,z-x)M(C,y-z)M(C,y-x)M(C,
x-z)M(C,z-y)M(C,x-y-z)M(C,y-x-z)M(C,z-x-y)translate A*E}#else Q(A,E,x)Q(A,E
,y)Q(A,E,z)#end#end union{M(0,0)rotate<45,145,0>translate z*2}//Andrew
Subject: Re: C/C++ question.
Date: 7 Oct 2002 11:24:51
Message: <Xns92A0B0F041DD6PhiLho@204.213.191.226>
"Andrew Wilcox" <awi### [at] unpuzzledcom> wrote in
news:3d9e1321@news.povray.org:
> I just can't figure out how to do it.  It's a simple simple thing to do,
> I just haven't worked in C/C++ so long, and I don't have any C++ books
> anymore.
> Now, POV wants the GUI Extension to pass the full path name of the file,
> let's say, "c:\povfiles\scene.pov".
int _access(const char *path, int mode);
mode Checks File For
00   Existence only
02   Write permission
04   Read permission
06   Read and write permission
Each of these functions returns 0 if the file has the given mode. The
the given mode; in this case, errno is set as follows:
access.
ENOENT Filename or path not found.
The Win32 API way is probably to use FindFirstFile, but it is too much just
for this...
You can also try to open it and check the result, but it is practical only
if you really need to open it.
>  How can I get the "current working directory" in a C program? in a C++
>  program?
char *_getcwd(char *buffer, int maxlen);
or
DWORD GetCurrentDirectory(
  DWORD nBufferLength,  // size of directory buffer
  LPTSTR lpBuffer       // directory buffer
No difference, as far as you do API calls, between C and C++.
Now, STL can have functions of its own.
> How can I tell if a file path is absolute?  This will only ever run on
> Windows, so Windows API calls are ok too...
AFAIK, it can start with '\\' (including network paths (UNC)
\\servername\...) or "<letter>:\".
You can also use _splitpath:
	char sDrive[_MAX_DRIVE + 1];
	char sDir[_MAX_DIR + 1];
	char sFName[_MAX_FNAME + 1];
	char sExt[_MAX_EXT + 1];
	_splitpath(path, sDrive, sDir, sFName, sExt);
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 7 Oct 2002 12:19:43
Message: <3da1b41f$1@news.povray.org>
Thank you!
