POV-Ray : Newsgroups : povray.windows : Never start more the 8 instances of POV-Ray on 1 machine with only 1 GB RAM ? Server Time
14 Oct 2026 23:23:01 EDT (-0400)
  Never start more the 8 instances of POV-Ray on 1 machine with only 1 GB RAM ? (Message 1 to 2 of 2)
Subject: Never start more the 8 instances of POV-Ray on 1 machine with only 1 GB RAM ?
Date: 15 Aug 2002 00:49:11
Message: <3d5b32c7$1@news.povray.org>
Yesterday - while looking TV I did some Extrem-Tests with SMPOV.
I tried to render with 8 POV-Instances a picture out of 600 tiles.
So At last it ended up in a povengine-crash with the messagebox
"no windows-resources". "click ok to end program ..."
Maybe 8 instances on a picturesize of 2000x2000 is somehow to much ....
Here is the good-news:
Staying with 2 running instances (on 1 PC and 3 other CPU's on the other
PC's) the following tests were running fine with the expected
picture-result:
biscuit.pov rendered in 2000x2000 in 400 Tiles (S) from 08-15-2002 /
00:58:03 to 08-15-2002 / 01:19:14 (1272).
desk.pov rendered in 2040x2000 in 500 Tiles (S) from 08-15-2002 / 01:24:04
to 08-15-2002 / 01:52:48 (1725).
landscape.pov rendered in 2040x2000 in 500 Tiles (S) from 08-15-2002 /
01:52:53 to 08-15-2002 / 03:21:12 (5300).
As the rendering was on only 3 PC's in this case the time is not intresting,
this was just a test if PP would
append properly even high tile-numbers.
Was nice to see that even 400 Tiles were automatically put together to a
perfect picture ...
wherever they are rendered.
--Theo
Subject: Re: Never start more the 8 instances of POV-Ray on 1 machine with only 1 GB RAM ?
Date: 15 Aug 2002 00:52:48
Message: <3d5b33a0$1@news.povray.org>
Must explain this more near:
The 8 instances are on 1 DUAL Athlon 2000+ PC.
Of course 8 instances distributed  on many PC's is no problem.
Also two instances on 1 PC has never made any trouble.
The described "windows resources"  problem could only arrise if someone has
8 Processors.
--Theo
"Theo Gottwald *" <The### [at] t-onlinede> schrieb im Newsbeitrag
news:3d5b32c7$1@news.povray.org...
> picture-result:
intresting,
> perfect picture ...
> --Theo
