POV-Ray : Newsgroups : povray.windows : GUIEXT Help. Trying to make Enabled status persist. Server Time
17 Mar 2026 04:20:38 EDT (-0400)
  GUIEXT Help. Trying to make Enabled status persist. (Message 1 to 1 of 1)
Subject: GUIEXT Help. Trying to make Enabled status persist.
Date: 2 Aug 2002 17:39:29
Message: <3d4afc11@news.povray.org>
I cannot do an (*Instance->Request)(RequestGetVars, &ExternalVars) ; in the
following method. I assume its because POV hasn't fully initialized Instance
yet. I need to know the Instance.HomePath so that I can read my .ini file
and initialize Instance.Enabled correctly.
What do I do?
Is there some place else I can set Enabled after POV has initialized the
DLL?  Or do I just have to know the directory where POV is installed,
without being able to ask POV itself?
Thanks in advance,
Andrew Wilcox
DWORD WINAPI PovGuiExtensionGetPointers (int RecSize, GuiPointerBlock
*PointerBlock)
   InstanceStruct        *Instance ;
... <code omitted>
   // READ THIS FROM AN INI FILE ! it should be persistent.
   Instance->Enabled = TRUE ;
   LoadPrefs(Instance);  // *** I cannot do an
(*Instance->Request)(RequestGetVars, &ExternalVars) ; in here.
   Instance->hInstance = hInstance ;
   // this is really a pointer to our InstanceStruct. don't confuse the term
'Instance' in this context
   // with Microsoft Windows's concept of an 'instance'. they're two
different things.
   PointerBlock->InstanceID = (DWORD) Instance ;
   return(TRUE) ;
#macro Q(A,E,W)box{-A/2,A/2pigment{rgb 9*W}translate E*A+W/1000}#end#macro
M(D,E)#local A=1/pow(3,D);#if(D<3)#local C=D+1;union{M(C,1)M(C,x+y)M(C,x+z)
M(C,y+z)M(C,x+y-z)M(C,x+z-y)M(C,y+z-x)M(C,x-y)M(C,z-x)M(C,y-z)M(C,y-x)M(C,
x-z)M(C,z-y)M(C,x-y-z)M(C,y-x-z)M(C,z-x-y)translate A*E}#else Q(A,E,x)Q(A,E
,y)Q(A,E,z)#end#end union{M(0,0)rotate<45,145,0>translate z*2}//Andrew
