POV-Ray : Newsgroups : povray.windows : Which System Server Time
1 Apr 2026 06:50:23 EDT (-0400)
  Which System (Message 1 to 10 of 18)
Subject: Which System
Date: 23 Dec 2001 23:40:49
Message: <3c26affe.70902@news.povray.org>
Running POV which windows based system is the fastest  (AMD or P4)?
Using optimised code for both sysytems is the difference still the
same?
How many memory is recommended?
Is the HD-speed (5400 or 7200) an important factor?
Greetings
Roland
Subject: Re: Which System
Date: 23 Dec 2001 23:57:02
Message: <3C26B573.C36048C7@pacbell.net>
The consensus seems to favor the AMD by a good margin.
> same?
From what I have heard, yes.
256 megs is good but 500 megs is better.
Only if you are reading in extremely large files. Otherwise it
really doesn't matter much if at all.
Ken Tyler
Date: 24 Dec 2001 04:19:38
Message: <oesd2ukloaoqp20kvo809b2qn3lfhkq5p6@4ax.com>
Or if your scene is so huge it has to swap heavily.
Mahy I recommend a Maxtor HDD? They're really, really quiet (even the
fan of my video board is louder) and therefore great for overnight
renders. The rest of their parameters (capacity, speed, price) are
comparable to most other vendors.
Peter Popov ICQ : 15002700
Date: 24 Dec 2001 07:09:25
Message: <3C271B21.F3ADA18D@ibras.dk>
Depends on the clock speed. A 1.7GHz P4 is comparable to a 1.2GHz
Athlon.
See www.tabsnet.com for benchmarks.
> same?
I don't think I have seen a specific Athlon optimised compile, but since
the Athlon thrives fine on PIII optimised code, the difference is still
there. Again see www.tabsnet.com
As much as your scenes need. Not more than 2GB, as that is the max that
POV can address.
In most cases: no. If your scenes takes a long time to parse, uses a lot
more memory, than you have RAM, but renders very fast, then it may be a
factor.
In my experience, having to use disk swapping has more impact on the
parse time, than on the render time. I have a dual processor system, and
I once rendered a scene (Railway Station), that used 200 MB memory. I
wanted to render on both processors, and since I, at the time, only had
256 MB RAM, disk swapping was necessary. If I started the two renders at
the same time, the parse time increased dramatically. If I waited for
the first render to finish parsing, before I started the second, neither
parse time nor render time increased much, as compared to a solo render.
(This is under Win NT 4.0)
/Ib
Gallery: http://www.ibras.dk
Date: 24 Dec 2001 07:14:17
Message: <3c271c19$2@news.povray.org>
however, with AMD your whole system rests on the VIA chipset - world renown
for being flaky
PGP Public Key
Date: 24 Dec 2001 07:35:31
Message: <3C27213E.9ECA47EA@ibras.dk>
> for being flaky
Yeah, but so is Windows, and that doesn't stop 90% of computer users
from running it - including me.
I have an Athlon system based on the Alimagick chipset, which is
supposed to be much worse than the VIA, and the only problem I have had,
is the occasional wrong temperature reading on the CPU.
/Ib
Date: 24 Dec 2001 10:24:30
Message: <3c2748ae@news.povray.org>
Ib Rasmussen <ib### [at] ibrasdk> wrote:
: Depends on the clock speed. A 1.7GHz P4 is comparable to a 1.2GHz
: Athlon.
  It depends on the application as well. With certain applications a
900MHz Athlon can clearly beat the 1.7GHz P4.
  The most important thing is price: How much does a 1.7GHz P4 cost? And
a 1.2GHz Athlon?
Date: 24 Dec 2001 15:53:35
Message: <3C2795FB.A5B824A7@ibras.dk>
> : Athlon.
The question was, how do they perform with POV.
/Ib
Date: 24 Dec 2001 15:58:27
Message: <3c2796f3@news.povray.org>
: The question was, how do they perform with POV.
  I doubt he will be using the computer exclusively for povraying.
Date: 24 Dec 2001 19:00:28
Message: <3C27C17B.664541E5@pacbell.net>
WHAT ELSE IS THERE????
Ken Tyler
