POV-Ray : Newsgroups : povray.windows : Random Numbers Server Time
12 Jun 2026 04:22:29 EDT (-0400)
  Random Numbers (Message 1 to 4 of 4)
Subject: Random Numbers
Date: 7 May 2003 22:18:18
Message: <3EB9BEFC.C7654D48@shaw.ca>
Does anyone know who I can generate random numbers for a loop.  I'm
creating a landscape for grass, I'm using the same bunch of grass each
time it goes through the loop and I want to give it a random size every
time.
Any help is appreciated.
Thanks.
Subject: Re: Random Numbers
Date: 7 May 2003 22:41:43
Message: <3EB9C3D4.EF10969E@pacbell.net>
Jeremy Kruger wrote:
> Hi,
> time.
You need to use the rand() and seed() commands for that. An example of
it's usage below. Add you own translate numbers. Changing the seed(1234)
number will change the beginning location in the random number stream
resulting in different results. Rand() will always return a value between
zero and one.
#declare SEED = seed(1234);
#declare A=0;
  #while (A<10)
   object { Grass_Patch
     translate <whatever>
     scale < rand(SEED), rand(SEED), rand(SEED)>
 #declare A=A+1;
Ken Tyler
Date: 7 May 2003 22:44:01
Message: <3EB9C45F.E9B45CA8@pacbell.net>
P.S. For a good loop tutorial check out -
http://www.f-lohmueller.de/pov_tut/loop/povlup1e.htm
Ken Tyler
Date: 9 May 2003 00:02:19
Message: <3EBB28DD.87CF19A1@shaw.ca>
> Ken Tyler
Hey, thanks a lot!
