Here at the computermuseum and the planetarium at the 'Fachhochschule'
(University of Applied Sciences) in Kiel, Germany, we have a handful of
connected computers running windows 2000. Currently I'm using POV-Ray 3.1
g
installed locally on only one of these computers, but I want to have 3.5
on
*all* of them, and hopefully we'll have more POVers here. To avoid having
to
install POV-Ray on each of these computers, I would prefer to (let my adm
in)
install it only on the server and use it on all other computers via netwo
rk,
but of course running locally.
Is it possible (and sensible) to provide POV-Ray for these computers in t
his
way without any admin-activity (except for installation on the server)?
Will POV-Ray need to write to any directories on the server (when executi
ng
locally)?
Will each user have its own editor settings / list of open files / file q
ueue /
rerender and continue information / MRU list / POVRAY.INI / QUICKRES.INI
etc.?
If so: are the individual settings stored locally or are they available o
n all
computers?
What is different (during installation / for the users), compared to a lo
cal
one-user-installation?
What else do I need to know?
I would be glad if someone could help me with this.
Sputnik
union#macro //+KFF9
F(R)cone{y.04<-3,2>.02
rotate(R-clock)*
x*45}#end{F(1)F(3)F(5)F(7)sphere{0 1}finish
{reflection 1phong
1}pigment{rgb 1}translate<clock*
7-5,1,7>}sphere{
3-<3,9>5pigment{blue 5}
}light_source {-y,1}
e-mail: fr### [at] computermuseum fh-kiel de
Subject: Re: POV-Ray on a network, for many users?
Date: 19 Dec 2002 08:12:52
Message: <3E01C5F1.40303@free.fr>
> Hi,
> connected computers running windows 2000. Currently I'm using POV-Ray 3.1g
> installed locally on only one of these computers, but I want to have 3.5 on
> *all* of them, and hopefully we'll have more POVers here. To avoid having to
> install POV-Ray on each of these computers, I would prefer to (let my admin)
> install it only on the server and use it on all other computers via network,
> Is it possible (and sensible) to provide POV-Ray for these computers in this
> Will POV-Ray need to write to any directories on the server (when executing
> locally)?
Povray can be installed on a network drive.
And it can write to a network drive (even if it is really ineffective).
In fact, an application usually does not care if the drive is local or
remote... but there is another issue: simultaneous usage of the same
files by different users...
> Will each user have its own editor settings / list of open files / file queue /
> rerender and continue information / MRU list / POVRAY.INI / QUICKRES.INI etc.?
> If so: are the individual settings stored locally or are they available on all
> computers?
There is three caveat: the Registry, ini/povengine.ini and renderer/rerun!
*.INI are usually in the shared installed "renderer" directory... you'd
better turn that subtree read-only once installed on the server, but I
do not know how to resolve conflict for rerun!
I'm afraid of conflict regarding ini/povengine.ini due to multiple
simultaneous access...
> What is different (during installation / for the users), compared to a local
Every users will have to write to its registry part (local!), but the
files would need to be installed only once on the server...
Would it not be simpler to put the pov-installer on the server and let's every user
install povray locally
(even if it waste the local disk space) ?
now I'm back again.
Thank you for your help.
Simultaneous read-only access seems to be no problem: POV-Ray 3.1 works
fine with (huge!) .inc-files used at the same time by 2 instances of POV.
> and let's every user install povray locally
Disk space is no problem, but installation on every single computer is
no fun:
- only our admin is allowed to install programs
- the current state of all computers is captured in system images, so ..
- ... if I install a program, it will be erased when the system is resto
red
- updates must be transferred to all computers, so I will have to find
out on which computers any of the users has installed POV-Ray; then th
e
update requires much time
What I would like to have is:
1. only one installation of POV-Ray on the server by admin
2. every user can use POV-Ray on every computer without any installation
and without admin
Is this possible?
Sputnik
"Le Forgeron" <jgr### [at] free fr> wrote in message
news:3E0### [at] free fr...
<snip>
Hmm, one can have multiple instances of Pov running on a local machine - would a
network-installed Pov be any different?
I would be happy if there were no difference, but I fear that:
- all users need write-access to the server's installation directory,
overwriting for example rerun lists of other users because POV-Ray
doesn't separate the users
- editor preferences, the list of open files, paths etc. are only
stored locally and not automatically available on every computer
Wouldn't it be fine to be able to go to any computer (even one which you
never used before), log in, start POV-Ray and automatically get your
personal settings over the network? In my opinion this would be especially
helpful in universities and schools, where many users share many networked
computers.
Sputnik
Date: 10 Jan 2003 14:10:49
Message: <3e1f1ab9@news.povray.org>
In article <3E1EFF06.A5880912@computermuseum.fh-kiel.de> , Frank 'Sputnik'
> computers.
Well, that is clearly the responsibility of the operating system. If WinDOS
does still not support this (are you sure it doesn't???), then use an
operating system that does.
Thorsten
"Thorsten Froehlich" <tho### [at] trf de> wrote in
news:3e1f1ab9@news.povray.org:
> WinDOS does still not support this (are you sure it doesn't???), then
> use an operating system that does.
> Thorsten
Not at all. If is the choice of the application developer to support
multiple users. There are many applications that do what he requires.
Windows POV-Ray is not one of them.
Date: 10 Jan 2003 20:51:08
Message: <3e1f788c$1@news.povray.org>
In article <Xns### [at] 204 213 191 226> , Tom Galvin
??? I don't get what you are missing. POV-Ray in no way depends on any path
or anything like that. So where is the problem? It definitely works this
way on the other two supported platforms, Mac OS and Linux without any
additional platform specific changes.
Thorsten
e-mail: tho### [at] trf de
> Hi,
> now I'm back again.
> POV.
> 1. only one installation of POV-Ray on the server by admin 2. every
> and without admin
> Is this possible?
Almost. After the admin installs POV-Ray on the server, you'll need to
update the registry on every computer that will be running POV to include
the key
[HKEY_LOCAL_MACHINE\Software\POV-Ray\v3.5\Windows]
"Home"="C:\\path\\to\\pov-ray\\install\\directory"
I think that's the only essential registry setting for POV 3.5
Mark
many thanks for the help.
Now I think we'll be able to get a user-friendly
multi-computer multi-user installation of POV-Ray
here.
Sputnik
