POV-Ray : Newsgroups : povray.windows : When PovRay will support IGES format? Server Time
12 Jul 2025 22:39:02 EDT (-0400)
  When PovRay will support IGES format? (Message 1 to 4 of 4)
Subject: When PovRay will support IGES format?
Date: 13 Jul 2000 12:35:13
Message: <396DFDD6.B4A29077@gal.logic.it>
Thanks.
Subject: Re: When PovRay will support IGES format?
Date: 13 Jul 2000 12:45:58
Message: <396DF101.C19E027A@pacbell.net>
Omnia Stampi wrote:
> Thanks.
Probably never. POV-Ray uses its own modelling language. You might
be able to convert IGES to .pov by way of a conversion program.
The only program that I know of that might be able to do this
would be Polytrans which is a commercial conversion program with
a pretty high price tag. You can check it out at -
http://www.okino.com/conv/conv.htm
Date: 13 Jul 2000 13:23:38
Message: <396DFADC.93100C40@t-online.de>
Perhaps never. One way to export: write a .ftl or .stl file (this are
files for rapid-prototyping). Those files contain thousands of
triangles. You can convert the format by a small program or perhaps even
thomas baiers convert-routine works with it.
Jurek
Date: 13 Jul 2000 13:50:15
Message: <396E001C.53CB4C8C@pacbell.net>
> Jurek
I am pretty sure that Thomas' conversion program has no support for
those file formats. There are a couple of .stl to .pov converters
that I know of however that should be able to do what you mentioned
at these sites -
http://www.geocities.com/SiliconValley/Pines/3014/proe.html
http://www.killozap.de/Download_E/download_e.html
