POV-Ray : Newsgroups : povray.windows : not really a bug but ... Server Time
15 May 2026 20:25:13 EDT (-0400)
  not really a bug but ... (Message 1 to 5 of 5)
Subject: not really a bug but ...
Date: 15 Dec 1999 21:08:43
Message: <385872E1.7384278A@ij.net>
Date: Wed, 15 Dec 1999 17:40:24 -0800
<bug### [at] povrayorg>
Subject: Re: Not quite a bug but
To: Matt Giwer <jul### [at] ijnet>
Organization: POV-Team
X-Mailer: Forte Agent 1.7/32.534
On Wed, 15 Dec 1999 15:49:48 -0800, you wrote:
>    windows version
>    insert|shapes|superellipsoid reads
>{ .25 , .25} instead of { <.25, .25>}
  There are likely more typographical errors than just
this one.
Several had been corrected from POV-Ray v3.0 to v3.1.
Please post this
in error in povray.windows and bring it to the
attention of the TAG
personnel. They may want to keep a running list of
typographical
errors in the Insert Menu items and the general POV-Ray
docs.
  Thank you for your participation.
b u g r e p o r t s <dash> m o d e r a t o r <at>
p o v r a y <dot> o r g
Subject: Re: not really a bug but ...
Date: 15 Dec 1999 22:56:38
Message: <385862f6@news.povray.org>
That strength/radius switch in blob is really confusing.
"Matt Giwer" <jul### [at] ijnet> wrote in message
news:385872E1.7384278A@ij.net...
> From: bugreports moderator
> >    windows version
> this one.
> Please post this
> typographical
> docs.
Date: 16 Dec 1999 00:57:53
Message: <Sn5YOKbyUEZiTBFDOPxqWCiao4lY@4ax.com>
On Wed, 15 Dec 1999 21:55:11 -0600, "omniVERSE" <inv### [at] aolcom>
>Bob
Can you please explain (or point out the correct post for me) this
blob problem so that I can keep track of it? Thank you.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 16 Dec 1999 01:03:49
Message: <38587FFD.57C85C40@pacbell.net>
> >Bob
This thread concerns the premade insert menu files. The one Bob is pointing
out comes from the insert menu for the blob object. In particular he is
refering to the way the radius and blob strength is defined for that object
as follows:
// create a smooth blobby shape
#declare StrengthVal = 1.0 // (+ or -) strength of component's radiating density
#declare RadiusVal   = 1.0 // (0 < RadiusVal) outer sphere of influence on other
                     // components
blob
  // threshold (0.0 < threshold <= StrengthVal) surface falloff threshold #
  threshold 0.6
  sphere { < 0.75,   0,    0>, StrengthVal, RadiusVal }
  sphere { <-0.375,  0.65, 0>, StrengthVal, RadiusVal }
  sphere { <-0.375, -0.65, 0>, StrengthVal, RadiusVal }
  cylinder { -z, +z, 0.1, StrengthVal, RadiusVal }
  // [sturm]
  scale 2
Wishing you Seasons Greetings, A Merry Christmas, and A Happy New Year !
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 16 Dec 1999 13:23:30
Message: <38592e22@news.povray.org>
Thanks Ken.  Yes, and in the Scene help looking up BLOB you get:
BLOB:
blob { BLOB_ITEM... [BLOB_MODIFIERS...]}
BLOB_ITEM:
sphere{<Center>, Radius, [ strength ] Strength [COMPONENT_MODIFIER...] } |
cylinder{<End1>, <End2>, Radius, [ strength ] Strength
component Strength, Radius, <Center> |
threshold Amount
COMPONENT_MODIFIER:
TEXTURE | PIGMENT | NORMAL | FINISH | TRANSFORMATION
BLOB_MODIFIER:
hierarchy [Boolean] |
sturm [Boolean] |
OBJECT_MODIFIER
Opposite of the Insert menu item Shapes/blob.  I believe the Insert menu is
incorrect, although it isn't all that easy to tell.  Fact is if you change
the first float value after the position vector(s) it obviously changes the
size, whereas the second (strength?) float does not.  Always confusing
unless you use it a lot sometime and have a good memory between times the
blob is used.  And btw, I may have mentioned it before here at the
newsgroups and got it backward then, don't know for sure : )
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38587FFD.57C85C40@pacbell.net...
> > >Bob
pointing
object
> as follows:
density
other                            // components
> blob
>   threshold 0.6
>   // [sturm]
>   scale 2
